It's a Sand Rail?????? My new toy
64 Notchback
Has thanked: 78 times
Been thanked: 37 times
Re: It's a Sand Rail?????? My new toy
Post by 64 Notchback »
Thanks Terry much appreciated.
Saves me from having to pinch the set from the Spyder.
John Alves
Been thanked: 48 times
Post by John Alves »
Pine wrote:Just a suggestion - fix it 'on the go'. Do one thing at a time - remove, repair/replace, re-install - drive!
I agree, otherwise it can sit for another 10 years
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
64 Notchback
Thanks to Terry (gave me a peddle assembly) I can now carry on with the clean-up of the Rail
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Glad I could help.
Good luck.
Glad I could help
64 Notchback
64 Notchback
This weekend I decided to play around with colour
combinations and the above is what I have narrow ed it down to. Although I quite like the grey.
64 Notchback
Has thanked: 235 times
Some inspiration...
64 Notchback
Nice and I quite like the colour
Anyone know where I can get hold of a NON working machine gun that I can mount on top of the bars of the Rail?.
64 Notchback wrote: Fri Mar 03, 2017 12:02 pmAnyone know where I can get hold of a NON working machine gun that I can mount on top of the bars of the Rail?.
I don't think that is such a good idea in this trigger-happy country of ours... :roll:
There are strict laws against the public display of weapons in SA, even if they are non-working or replicas. Search for 'Mike's Models' on FB - Mike makes resin replicas of all types of weapons, you can also contact him at 072 222 6789 or look at his web site www.sadfi.org/. He should give you the correct information.
...or you can install a high-lift jack on it? :mrgreen: :mrgreen: :mrgreen:
64 Notchback
Over the past month I have been cleaning out my garage and general cleanup around the house and found some stuff to cote the rail. It is called Belzona we sell it at work. This particular product is used to create a non slip area but I did not use the grit.
I decided to cote the inside of the rail with it, only thing is you only have about an hour to work with the stuff as you mix it with a solidifier. It think it will also help protect from rust
64 Notchback
This is what it looked like before I started
I will be doing the same to the beach buggy pan
Piet
What model do you have?: type 3, Porsche 550
Been thanked: 15 times
Post by Piet »
64 Notchback wrote: Fri Mar 03, 2017 12:02 pm Nice and I quite like the colour
64 Notchback
Yeah you got one
