Just how strong is a Beetle gearbox?
vader
Post by vader »
Not spinning the wheels
vader wrote:there is a gearbox brace that you can make at home if you can weld and use a ruler and a drill. its made out of square tubing and bolts onto the forks and then up under the dogbox and then another brace is bolted inside the car where it comes threw the floor and onto the wheel arcs. This strengthens the gearbox on the forks and stops the twisting motion induced by torque of the engine. It's cheap, it work really well and you can do it in one afternoon..... Well for MTM maybe two!
and then you twist the body.... You may as well use the engine hanger setup, with a square tube mounted under the rear end (oil pump side) of the engine and the tube bolted to the bumper mounts
Merlin
Has thanked: 20 times
Been thanked: 39 times
Post by Merlin »
I have one for sale if anyone is interested.
New from CB. Chrome. Has all of it's mounting hardware.
My bug's getting a gearbox midmount and Bugpack KCB. :)
Is that the one for R400-00?
Merlin
Post by Merlin »
Yup.
4agedub
Been thanked: 13 times
Post by 4agedub »
A stock beetle box is stronger than you think... I've been running my box for about four years now without any problems. Previous engine made 95kw on the wheels and I drove like a hooigan... dougnuts burnouts etc
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
I'm sure that a 2,0 Type 4 that's very close to stock won't destroy a standard Type III gearbox :D
4agedub
Post by 4agedub »
Your gearbox should last forever with a stock type 4.
