Thanks Dawie!Dawie wrote:Thermostat.
On Samba forum,most people think its best to keep thermostat,unless the vehicle is used for drag racing.Noticed that Werner Alker keeps thermostats on his vehicles.
It is designed to fail in the open position,strong spring pressure forces it open when punctured.
Engine will last longer with thermostat,have more power sooner after startup and use less fuel,especially in town.
Its not in a mechanic s interest for jou to have a thermostat.It is easier to install the fanhousing when the thermostat rod is missing. He doesnt pay your fuel,and its not in his interest that jour engine lasts too long.
I have cylinderhead temp gauge with sending units on both heads and switch between them,also have oil temp gauge.My engine didnt have thermostat.It took forever to heat up and didnt get near operating temp in town.Bought the missing parts. Made a big difference in fuel consumption in town,also smoother to drive.
Others may differ ,most of them do not have cylinderhead temp gauges or keep accurate record of fuel consumption.
The thermostat set-up serves a purpose. If VW didn't need to put that complicated contraption on your engine they wouldn't have.
The thermostat ensures that your engine warms up evenly, regardless of ambient temp. Your engine has a magnesium case, iron cylinders and aluminium heads. These metals all heat up and expand at different rates. The thermostat and flaps ensure your engine warms up fast and that those three metals all expand at similar rates.
If they don't, you get microsopic movement of all those parts against each other, which causes the cylinders to grind into the case.
That unwanted movement, coupled with longer warm-up, translates to measurably reduced engine life.
