Wreck Rescue - aka The Notch
Love it! :hangloose:
Well done on all the work Ferdi.
Has thanked: 19 times
Wow I better step up with the Squary with all the work you guys put in to the Notch
Keep going doing good Ferdi :hangloose:
:bowdown:
:shock: :shock: :shock: :shock: :shock:
AWESOME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Your idea with the Rostyles is a good one. Detail them nicely and they would look great 8)
STUNNING, AMAZING and GORGEOUS!
Has thanked: 235 times
Awesome! :hangloose:
(I know what will be the cd in the Notch's player... :wink: )
Farhaad
Post by Farhaad »
ferdi- what more to say than what has already been said :hangloose:
And Oliver Twist asked, can I have some more please sir ?
Remember the bootlid I was looking for?
Turns out that MR Bugoff here was just being lazy :twisted: - **ducks** .
He just needed to work some of his magic on it.
Please bear in mind, I went to go take a look at the bootlid, the rear strip was almost rusted away completely, swiss cheese.
The thin strip that it attaches to was also bent and broken. REAL STATE.
Before pics as a reminder:
Now it looks like this:
:hangloose: :hangloose:
Karma,do you still want that thing that we spoke about a while ago? Or can I put it into the fasty :P
Blitz, if it's that round thing you turn corners with, and it will help get the fasty ready sooner, then put it in the fasty, I still have the notch's thing :wink: :mrgreen:
Tell you what, i'm going to have it recovered in the meantime, then if I don't use it, you can put it in the Notch...
Sounds like a plan :hangloose:
What colour you going with, black, black or black ?
Black :)
A quick ad break.
No work done over the holidays, but paint coming in January! :D
Watch this space.
I did find time to do the following though:
Remember the Type 3 Clock I got from Muds?
Took it apart (CAREFULLY !).
Polished the shiny bits, cleaned the "glass", sanded off the rust on the rim, and then paint.
Closest paint match was actually grey primer! So I gave it two thick coats.
After drying and reassembly, we end up with this:
Not Perfect, as there are some slight sratches on the glass and chrome, but good enough without replacing parts and all original. :hangloose:
I suppose to test all we need is 12V ? Anything I should be wary off when connecting it to the battery? 12V positive to the tab sticking out the back and ground to the body of the clock right?
JamesD
Been thanked: 20 times
Post by JamesD »
Looking good, I would be rather happy with a clock in that condition after seeing how it started :wink: So yours only has one tag, Hmm, the VDO in the 924 had 2 tags i think, one + and one -. I would couple it up and see what happens. if those clocks tick for each second couple up for a second or 2 and see if it ticks...
From fastest to slowest:
'75 SP 1600 with a few mods
