My Baja Bug Rebuild
Edmond
Has thanked: 22 times
Re: My Baja Bug Rebuild
Post by Edmond »
Some more progress, added metal in the areas that had big gaps, patches were the holes are someone had previously drilled in the pan, added more welds where the replacement section was welded in and repaired the rusted area by the accelerator pedal mount with some 2mm mild steel.
Getting everything to fit is the hard part, the welding goes quick. I also ground down the welds and sprayed them with zinc primer for rust protection in the interim as it may be a while till I work on the chassis again.
The homemade chassis flipper is also finished, just made from 114 x 32mm pine with castor's.
Edmond
Post by Edmond »
A little more progress, the underside of the pan has it's first coat of Duram DTM paint on. I still need to paint the pain rails though. I need to paint to the top of the psns/chassis as well. My favorite angle grinder disc for prepping the pans are the strip and clean discs from Fowkes Brothers, they make light work of stripping off paint and rust. I need to replace the spring plate bushes on the chassis along with a host of small things to do on it. I purchased more replacement parts recently for the chassis. Once the pan/chassis is all painted, it's time to swap over the gearbox, front suspension, engine and got the braking system. The car still needs the bodywork to be finished, a few rust repairs and the front inner wheel well repair panels fitted.
Edmond
Post by Edmond »
A little more progress to share, top part of pans has been cleaned and coated with it's first coat of Duram DTM paint. I also tried out my R125 sandblasting gun I got from Temu a while ago, does a fairly decent job of getting rid of the rust.
I also recently purchased a set of chrome 5 star rims with good tyres, these rims will go nicely with the bull bars, side bars and engine cage I recently had powdercoated silver.
Hoping next time to finish painting the pan and chassis, I'm so motivated to get this car on the road.
Edmond
Post by Edmond »
A little more progress made, the chassis has its second coat of paint on the top of the pans and the complete underside. I still need to paint the pan rails, top of the frame head and the rear suspension uprights plus spring plates. I'm aiming to work on the chassis thus coming Easter weekend and try to finish painting it.
Been thanked: 112 times
Post by Haans »
Keep it up !!, soon you will be under the wife/ "friend's" feet, not knowing what to do next 🤣🤣.
Regards. Haans
Edmond
Post by Edmond »
Some progress from 2 weeks ago. Frame head top is all painted and the pain rails painted.
I pulled apart the rear back suspension, looked like water got in one of the torsion bar tubes at one stage but luckily a bit of penetrating oil spray loosened things up quickly.
The torsion bar rubber bushings have seen better days but I have replacement ones on hand.
Next time I will clean and paint the spring plates and torsion bar covers along with the rear suspension uprights.
I managed to get a nice set of seats recently which are covered in nice material, I still need to collect them
Also have a set of rear popouts on the way and more new parts on the way.
Edmond
Post by Edmond »
The seats arrived, I got them for a good price and they are in excellent condition.
I'm hoping to make some good progress this coming Sunday.
Been thanked: 101 times
Getting there, Edmond! Keep it up.
Edmond
Post by Edmond »
At long last the back suspension has been installed with new spring plate bushings and painted spring plates plus covers.
Next is to get the body up on its body dolly and start stripping parts off the old chassis to clean them up and fit them in the refurbished replacement chassis.
Refurbished replacement chassis is patiently waiting.😊
I really need to start making some headway on this project.
Post by Haans »
Hi young man,.....keep it up,....before you realize it you will start looking over the fence for the next project 😂😂.
Glad that you "refurbished" the pan too
Thanks for sharing...........awfull quite on this forum lately
Regards Haans
Edmond
Post by Edmond »
Not much progress made on my Baja lately.
I did manage to get a s/h AS code gearbox complete with axle tubes and axles. I did start cleaning the gearbox in preparation for a nice coat of paint. I managed to clean up the axle tubes and paint them before time ran away with me. I need d to swap out the nose cone on the gearbox because for some reason it has a early 2 bolt nose cone on, it was probably swapped in a early/pre 1973 beetle..
I also got a spare cam I had saved for a special occasion reground into a 280 degree rev master grind and a set of OE followers refaced by Mastercams.
Edmond
Post by Edmond »
The gearbox and the replacement nose cone got a thorough cleaning and them got painted with black etch primer plus 3 coats gloss black aerosol spray paint. The cleaning took a lot longer than expected. Got a nice alu crank pulley but the degree marks are worn off, I might jig it up on the cnc at work and engrave the marks on permanently and then fill them with black paint.
Post by Haans »
Hi ,.. I'd like to see the pulley when done,..... slow & steady boet !!!
Ps.... it seems that lately it is you ; Allanh and I on the forum....... really stone dead...... can all the project really be done . me thinks not!!
tjeers Haans
AlanH
Has thanked: 129 times
Been thanked: 87 times
Germany
Post by AlanH »
@Haans, quite sad actually.
Wanted parts:
Left sunvisor
Sink faucet
I'm still here occasioanlly. I'm so busy at work that I only turn on my personal laptop about once every 10 days... If I'm lucky, I get time to check my private emails once a day.
