The place to ask your "Stupid Questions" thread!!
dsan
Twin Port
Re: The place to ask your "Stupid Questions" thread!!
Post by dsan »
How does one fix a dodgy choke?
New carb, less than 2000 miles on it and starting in the morning is a bitch. It's blatantly obvious the choke has gone into overdrive, and takes for ever to turn off. The result is a spluttering dub with copious amounts of petrol being thrown around.
I'd disable it if i could as after 30 mins, she's as right as rain.
Daniel
Been thanked: 21 times
Post by Ron&Gill »
Have you adjusted it?
dsan
Twin Port
Post by dsan »
how does one adjust the choke on a brosol H30/31 pict? I thought it was all automatic?
Daniel
Post by Ron&Gill »
If it is essentially the same as the Solex, then the thermostat (spring thingy) is in a round housing held down to the side of the carb by a ring with three screws. When the engine is cold (thermostat-spring-wire-thingy has not had electricity going through it for a long time) i.e. the choke is on (the butterfly is closed) loosen the screws and turn the housing anti-clockwise (opening the butterfly) until the butterfly is still JUST closed, almost-almost (that ampertjies-ampertjies in English) starting to open and then tighten the screws again. Obviously you gotta be looking down the throat of the carb...
I hope this is right, it's what I've always done and it's always worked for me. I'm no carb expert.
dsan
Twin Port
Post by dsan »
danke danke, will try that when it's cold as right now it's being abused all over town by the wife
Daniel
Post by Ron&Gill »
Maybe it's clockwise... no... I'm sure it's anti-clockwise...
Bad Ass Bob
Post by Bad Ass Bob »
Ron&Gill wrote:No, the lack of reduction boxes does not give more space because the wheels catch on the drum, not the box.
No the wheelbase after a straight axle conversion is the same because you use long shafts and extended axle tubes.
The question thus remains... :lol:
Use any type 3 box and shafts they are shorter and have bigger drums !!!!!!!!!!!
Has thanked: 45 times
Been thanked: 208 times
Looks like the T2D kit has adjustable spring plates. Imagine you would have to "un-lower" it before removing the wheel...
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
Hi R&G I know what you mean, and no there is no solution i have made a "tool" that locates on the spring plate to force it down in order to get dem wheels off.Its stashed in the back of my bus but im still hopefull not to have to change a rear on a trip :roll:
Post by Ron&Gill »
Spoke to Paul Medhurts of T2D, he says the adjustable spring plate help as you can lower them. Sounds like a pain in the hynie to me... Get a flat, end up having to readjust your suspension...
Hloni
Has thanked: 14 times
Post by Hloni »
Can someone please explain why one should NOT have petrol filter in the bay? Been reading of a fella who had a fire in the compartment.
Just in case you wondering, last year l heeded the common warning and stashed my filter under, but l never realy got to know WHY. I have seen bugs with filters in the bay, which means they survived 30+ years!
3011
JamesD
Been thanked: 20 times
Post by JamesD »
Will this work on a type 1? dont want to use it at the moment but just wondering since it has always been in the box of aircooled parts ...
From fastest to slowest:
'75 SP 1600 with a few mods
Sambabus
Short Block
Has thanked: 39 times
Post by Sambabus »
Hloni wrote:Can someone please explain why one should NOT have petrol filter in the bay? Been reading of a fella who had a fire in the compartment.
You shouldnt have a fuel filter in youre ENGINE bay,the preasure from youre petrol pump may blow the filter out the fuel hose,or the hose clamps could come lose and the filter falls out and pumps fuel all over youre engine,...its no secret that youre dizzy shoots sparks everywhere when the motor is running and that the hot exhaust manifolds are really easy to get to.....you should have youre filter neatly tucked away outside the engine bay,underneath the car or in the wheel arch,..out of harms way,....and check youre fuel lines regulaly,dont use braded hoses either,..the weav hides cracks,steel lines arent that good either,because of the movment of the engine,if you do use steel fuel lines have short pieces of regular rubber fuel hose on the ends,where ever they connenct to the engine....always carry a fire extinguisher in youre acvw... and drive safe.Happy motoring.
dablakmark8
What model do you have?: rat 66/67
Post by dablakmark8 »
tell me are the 1960 fenders the same as a 67 or is the 1960 fender longer and lower?They look different but by how much in length.
The only good answer is the one that destroys the question.It takes a nation of millions to hold us
Hloni
Post by Hloni »
I have reached a stage where I need guidance from the OG Brigade. How do I respond to this without loosing my faith, cos the next time someone utters these words, I think I am goin to FLIP!
"You goin' to do it up, fit mags and all?"
3011
