+1Blitzkrieg wrote:If you don't mind sharing, what did the final cost of this come to?
1914cc Type 1 customer engine build
- riaanj
- Has thanked: 6 times
- Been thanked: 41 times
Re: 1914cc Type 1 customer engine build
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
- 4agedub
- Has thanked: 4 times
The total came in just over R80k. I did not charge any labour as this was a favor to the owner. If I had to charge labour it would probably have to be at least R10k more due to all the specialized machining.
The only parts we used from the old engine:
-Carburetors with air filters and linkage
- Fan housing, alternator, alternator stand and engine tin
Everything else in the engine is new. Casing, crank, rods, cam, gears, pistons, oil pump, barrels, heads, rockers, ign system etc.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
Ohh my hat that is nice.. I guess you have to be prepared to pay for such quality.
Too much for my pocket, but then again, I'm not after such performance, just would like a DRY motor.. ahem..
Anyways, best of everything to the new owner, stunning work there 4agedub.
- Dutch_Diver
How much power do you think it will produce? It's really cool
- 4agedub
This engine should make around 90kw on the wheels @ 6500rpm. My dad's 1914cc t1 made around 85kw on the wheels which is good enough to pull just over 170km/h at zwartkops
