1962 T1 resto cal project
62RestCal
What model do you have?: 62
Re: 1962 T1 resto cal project
Post by 62RestCal »
I'm now busy tackling the front beam, got the spindles off and lucky for me the link pins were in pefect condition, (obviously replaced just before i got it) i really hoped the king pin looked the same and thank goodness it did, i did have to find new fibre thrust washers though and adjust them to the right thickness. The new dropped spindles are on and look goodImageImage
62RestCal
Post by 62RestCal »
I was considering powder coating the beams but on advice from Merlin opted just to paint them, took them to get sand blasted today. Trailing arms are stripped of old paint, polished and sealed with Q30.ImageImageImage
62RestCal
Post by 62RestCal »
19mm anti roll bar powder coated satin black.Image
62RestCal
Post by 62RestCal »
Made some more progress on the front end. Had it sand blasted and then i proceeded to paintImageImageImageImage
62RestCal
Post by 62RestCal »
Messiest part of the build so far was cleaning up inside if the torsion beams and bars, got them nce and clean making sure to mark them all so they go back in the same way, greased them back up and now busy reinstalling! Urethane bump stops will have to go in after the it is back on the car.
62RestCal
Post by 62RestCal »
Nice shiny tierods with new ball joints and zinc plated nuts and locking platesImage
Jdt1976
Has thanked: 116 times
Been thanked: 90 times
Post by Jdt1976 »
Good inspiration!
62RestCal
Post by 62RestCal »
Thanks, I was told to post pics[emoji4] so thats what i'm doin
nice work
51splitfanatic
What model do you have?: 1957 Oval
Has thanked: 42 times
Been thanked: 13 times
Post by 51splitfanatic »
62Restcal,
The workmanship is perfection..really good work!!! I realy love the thread so far....I not read so good...me likee da pictures tooo much... :P
Words of caution just as a lessons learned as I learned the hard way:
Dropped spindles widen the front wheel track by a cm on each side, which does not seen like much...but.....just look at your wheel offset and your choice of brakes if it be drums or disc and that may make or break the hard work that you put into that beam....!! Looking at the work you have done so far......I think that you most probably would have planned for that already...I just had to throw my 5 cents worth in there. :wink:
62RestCal
Post by 62RestCal »
Hehe thanks, Pierre, i know exactly what you're talking about and i did look very carfully at my wheel's ET before i baught them. Norrowed beams are very impractical so thats why i've been quite carefull, they should fit in nicely. I just like the ride of the dropped spindles more, no need for castor shims ect to get the ride right.
51splitfanatic
Agreed....narrowed beams can give the right look at times, but has it drawbacks......it looks right, but drives like a tractor..!!! I just shudder to think how some of those people drive with their what I called " Slammed prams" Yep...once again in agreement....dropped spindles is the way to go...drop that Volksie the cheap way without castors shims and find out what a Volksie feels like with luxury cars very overactive power steering..one minor rut in the road and you end up a street down from your house if you do not hold on to that steering wheel.
Enjoy and keep on posting pics...it starting to feel like Gas Monkey...cannot wait for the next episode...LOL!!!
Pierre :hangloose:
Guest
Post by Guest »
Thanks Pierre, just wish i had some if GMG's toys/tools! If you got please send me some pics of your 66, i'm too curiouse to wait till the 21st!?
62RestCal
Post by 62RestCal »
Thanks Pierre, just wish i had some of GMG's toys/tools! If you got, please send me some pics of your 66, i'm too curiouse to wait till the 21st!?
Donovan D
Has thanked: 150 times
Been thanked: 73 times
Post by Donovan D »
Wow !! Really great work and great inspiration ! Keep the pix coming.
Is that an Adendorff water trap on your compressor ?
