It's a Sand Rail?????? My new toy
64 Notchback
Has thanked: 78 times
Been thanked: 37 times
Re: It's a Sand Rail?????? My new toy
Post by 64 Notchback »
Finally got the gearbox fitted the the Rail
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Good to see some progress,looks good Thomas.
64 Notchback
Thanks Terry
Hope to fit the backing plates and drums today
Been thanked: 109 times
Post by Haans »
Looking good !😎 🛠
Whats the colour on g-box ?,........me likes it!
Regards Nick
64 Notchback
Thanks Nick
The colour is called EAU DE NIL . It is a chemical resistant two part paint.
I also painted the backing plates and drums which I wanted to fit today but could not, and also painted the tank, spare wheel stand and side mirror fittings in the same colour
64 Notchback
64 Notchback
Did abit more work on the engine today
Had to cut one of the trumpets as they were welded.
64 Notchback
Has thanked: 424 times
Been thanked: 542 times
Coming on very nicely
You making us all GREEN with envy..
:TIC:
64 Notchback
Time for a little update..
Over the weekend decided that I have neglected the Rail for to long and spent some time cleaning up and reconning the master cylinder, which was done and then tried to install the peddle assembly, also done.
BUT..... when it came time to thread through the clutch cable different story as the tube that the length of the tunnel sits on the right hand side and the hook for the eye of the cable sits on the left, which I don't think is correct as the cable then has a kink in it crossing from right to left?.
At first I thought it might be a let hand drive floor pan but no, there is no hole for the M C plunger and the accelerator cable tube is on the left side.
To remedy this I pushed through a length of 10mm ID tubing from the back of the pan to run along the left side of the tunnel to enable me to fit the cable.
Thanks for reading.
64 Notchback
This weekend I cut the tube to size that I had to install for the clutch cable and threaded the cable through.
Having done this i was able to fit the peddle assembly.
64 Notchback
Did some more work on the project this weekend.
Got the dash sorted and fitted and also fitted the steering wheel.
While i was feeling energetic i trial fitted the seat rails
From this....
To this......
64 Notchback
I was abit concerned about the wood board that one of the spare wheels is kept.
So i coated it with a layer if Belzona and it came out quite nice.
64 Notchback
Finally got the stickers that i ordered.
cool
