"Eva-Ann"
- Batman
- What model do you have?: 1971 Beetle 1600 TP
- Has thanked: 4 times
Re: "Eva-Ann"
.... washed her last night before the rain
Re: "Eva-Ann"
Nice, you should come down to PE and wash all our cars, .... we need lots of rain...
- Batman
Re: "Eva-Ann"
The previous owner rubberised the interior for some reason. I thought that it was still in a good condition and that I would just clean it out and I would carpet over it.
But the weekend with some closer inspection I realised that it was lifting and that the one door is leaking, causing water to build up between the rubberising and the floor-pan.
Here's some before photos.
- Batman
Re: "Eva-Ann"
Started lifting the rubberising ..... this is not going to be an easy job.
Agree, can't decide on the interior yet.
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
Re: "Eva-Ann"
A heat gun should do the trick. There is always some hidden surprises.
- Riaan.N
- Oil Seal
- Has thanked: 3 times
- Been thanked: 38 times
Re: "Eva-Ann"
One possible reason for the rubberising is that helps with noise isolation. A better approach, in my opinion, would be to install a purpose made noise isolation material like Dynamat (there are probably some other brands as well).
Re: "Eva-Ann"
If you can get dry ice, or Liquid nitrogen, Spread it over the rubberizing and you will hear it crack
Then just lift and remove with a scraper, as it will be loose, wear gloves, or loose you fingers.
- Pushrod
- Has thanked: 141 times
- Been thanked: 100 times
Re: "Eva-Ann"
Pro Auto Rubber is now selling a product which does heat insulation as well as sound deadening, at a fraction of the cost of Dynamat. I've bought some and am very satisfied with it.
- Has thanked: 78 times
- Been thanked: 37 times
Re: "Eva-Ann"
if you go the Dry Ice route then there is a place here in Spartan that sells pellets and blocks of dry ice (Dry Ice Africa)
- Camshaft
- Been thanked: 107 times
Re: "Eva-Ann"
There's nothing like the day after a couple of blisters and broken skin over the knuckles!!!!
It works for a bit of attention from the missus / girlfriend/partner !!
- Pushrod
Re: "Eva-Ann"
I'd go marine vinyl. It's more expensive than Kehl's vinyl but stronger and more durable. Also more UV resistant.
