1978 SP Beetle Project
Herbie
Been thanked: 35 times
Re: 1978 SP Beetle Project
Post by Herbie »
This was a good weekend...my fingers are sore but the progress was good. I stripped off the old stickers on the roof and replaced it with a new set. At the same time I replaced the window rubbers of both the rear quarter windows...next time I will do it in summer ImageImageImageImage
Blood Type: VW+
1978 Beetle SP 1600
1963 Beetle
Eugene
Has thanked: 59 times
Been thanked: 65 times
Post by Eugene »
The car is really not looking very pretty. I am looking for a car to build a Baja.....this will be a nice base. Let me know if you want to swop vor Cortina v6 engine :TIC:
Riaan.N
Oil Seal
Been thanked: 38 times
Post by Riaan.N »
Looks very nice...Good job!
The thing that pats my back, is when I look at my beetle and know/remember all the things/work I have done on it...and it never gets old
Good progress made
Herbie
Post by Herbie »
Made Some good progress over the last few weeks. I cleaned out the wiring in the nose and fitted a new headlight relay. I also had the 14” Rostyles repainted and added a set of fresh rubber. I drilled holes in the front fenders that someone closed off very meticulously, in order to fit new round reflectors. I also fitted an original SP radio. I had to build modified brackets as someone cut the dash hole bigger at some stage.
Blood Type: VW+
1978 Beetle SP 1600
1963 Beetle
Herbie
Post by Herbie »
The mystery of the colour of my SP is solved. When I bought the car it had some parts missing...after some research, and speaking to some experts I gathered enough info on SPs to write a complete article, including a method to “read” the VIN plate. My newfound wisdom unfortunately revealed that my red car in fact was not supposed to be red...the paint code for the Calypso Coral red for the SP is 14 and my car's paint code is 40.
Thanks to IMPI I now have a colour card of the code 40...Topaz Metallic Gold!
So I guess a respray is on the cards for the future. I still have one mystery to solve and that is why there would be gold on a SP. so far John Lemon and IMPI's combined theory makes the most sense...my car is a 78, one of the last SPs and someone with deep enough pockets, and maybe a connection at a dealer, ordered one in a special colour...who knows? The truth is out there...
I have also finally managed to get the RWC and license...now I can finally drive my car around!!!
Blood Type: VW+
1978 Beetle SP 1600
1963 Beetle
Camshaft
Been thanked: 107 times
Post by Haans »
Go forth !! Enjoy ! Let the purists worry about the correct colour for a while 😏😏
good news on the RWC. Enjoy her and take more pictures
Lovely SP.
What size tyres are you using on those Rostyles?
I'm busy with a 76 Beetle and thinking of going the SP look
Herbie
Post by Herbie »
Hi. I fitted 185/70x14 and they do not look too bad.
N
Blood Type: VW+
1978 Beetle SP 1600
1963 Beetle
Herbie
Post by Herbie »
I am super excited about my recent change. When I got the car it had the linkage that came with the 44 Webers...the one that pushes from the top.
Not only was it too big and in the way so much so that I could not fit the rain catcher I sourced, it was a horrible drive.
I sourced another linkage through IMPI which is very much the same as the SP linkage and fitted it recently. I completed the job today and boy o boy...it makes a huge difference. The throttle response is excellent and feather lite. It fits the same way as the SP linkage, underneath the alternator. I am super stoked. I now need to fit a new pipe to the breather system until we can back to the original breather system. Slowly but steady we are getting there.
Blood Type: VW+
1978 Beetle SP 1600
1963 Beetle
Good move.
That looks like the old B.A.S style linkage - very good product
The centre linkage section looks like a China item that comes with the China carb kits?
Camshaft
Post by Haans »
Herbie boet,.....can you give me a closeup or two ofthis setup you have now,....sitting with an engine "links" on a Dellorto setup,.....but have no plan yet on how to get it to work without messing up the current cabling system.
Want to go this rout as above ,..but have no drawing or sketch,....take it the angles are important.
Regards Haans
Herbie
Post by Herbie »
Hi Haans
No worries. This is as I have it installed. We are still trying to figure out whether the block bracket must go in this way or turned around 180 degrees...same pudding, just another sauce. I twill offset the center to the right about 12mm if you turn it around.
Blood Type: VW+
1978 Beetle SP 1600
1963 Beetle
