MY 65 TYPE 4 POWERED SUNROOF BUG
- hitlers revenge
- Been thanked: 36 times
Re: MY 65 TYPE 4 POWERED SUNROOF BUG
Hey Bugger, Why? to the axle boot story. I always put mine at 90 degrees
- Has thanked: 19 times
Take our hands put them together as you would pray like you fit them 90deg then try and do a flex movement with your fingers you can split all your fingers apart but cant "Flex" them up and down
Now just turn your hands slightly to left or right now you are able to "Flex" your 2 hands Slightly up and down
When the boots are 90deg that is 2 thick pieces of rubber next to one another where you bolt it together and more difficould to flex up and down but if you just turn it slight to the 1 or 11 O clock position the 2 pieces of rubber is easier to flex and I just personally prefer to do it like so the other way work as you say you always do it like that but I think the other way is better
- hitlers revenge
- 66looker
- What model do you have?: 1966 bug
Hey all..... i think i found the look and colour i want what do you think?
I have those wheels already
'HE WHO KEEPITH HIS MOUTH KEEPITH HIS LIFE'
I've seen a new Lexus in that colour. It looks awesome in the sun!!
- Has thanked: 36 times
- Been thanked: 50 times
hmmmmmmmm, I'm not a fan of pearl white on a beetle.............looks a bit too plasticy.
each to his own.
each to his own.
- 66looker
The gauges are vdo got them for free am gonna take them to speedo services to swap out or calibrate. Got my wheels.......
Are those the ones from PE?66looker wrote:The gauges are vdo got them for free am gonna take them to speedo services to swap out or calibrate. Got my wheels.......
MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM
The project is comming along good
- 66looker
yeah got them from marlene.......... cant wait to get it all together
anyone knowwhere i can get adapter plates 5x100 to 5x130 pcd?
Calooker sells them.
