Matt
What model do you have?: '78 1600
Re: My ex type 1 turbo project (Changing to Historic Racer)
Post by Matt »
i envy the budget you guys get to work with. i think alot of us could only wish to have so much
bux to put into our cars.
so far the thread is kickass, love to know what times you get when you finally finished
good luck
4agedub
Been thanked: 13 times
Post by 4agedub »
The best way to build a car like this is over time. Buy a couple of parts each month and keep them aside. (do not keep the invoices :) those will make you go crazy)
It's actually not that expensive to build a car for historic racing. You can get away with a load of std items. All depending which class you wish to compete in. For class F you would be able to run a stockish 1641cc without problems. You just need handling
She ran a 1:18 at Zwartkops. I've never been to phakisa before so lets see what happens.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
dubster
Post by dubster »
could you maybe put that in relation with other cars....did sarel van der merwe race his galaxy?what times did he run if he did....and all those funny looking porche race cars and escorts and rotories....ive never been to zwartkops so i have no idea of the times cars run around there....
1974 1300tp type 1
kart kraft 1717cc buggy
Re the budgets... 4age is right, collect things slowly and put them aside.
For my engine, I spent 7 years collectng parts before I started assembly.
And as 4age said, dont keep the receipts. I have a special bin for my receipts... one day when I am feeling brave, I will take them out and add up the damage. If you have a budget, you will spend at least double that at the end of the day....
Been thanked: 21 times
Post by Ron&Gill »
Agreed. How much does it cost? Make a fair estimate, add 50%. Then double it to finish the job. That's excluding fire damage...
4agedub
Post by 4agedub »
And of course don't tell your wife how much you spend. Also make sure that she does not get the slips. :)
*Dreams of a 2,1 Type 4-powered fasty in Gulf Colours racing in Historics*
2BugMe
Post by 2BugMe »
Hey guys,
At that rate ill be freaken 105 before i turn the key to my dream car...lol :roll:
Anyway, dude how come you run such high compression and how do you controle detonation or pre-ignition??
btw, who did those heads you used and as you dont have pics please describe a bit of what you did to keep them bullet proof??
Shot
:hangloose:
4agedub
Post by 4agedub »
I'm running her on 95 octane fuel, max timing under full throttle 28' advance. No detonation.
Compression makes power, but also produces heat.
My dad built the heads ages ago, cant really remember the valve sizes. But they have got special valve guides that wont fall out. Also running doulble valve springs with cro moly retainers and collars.
2BugMe
Post by 2BugMe »
imported springs?? What make?? At what rpm should 1 consider dual springs??
Shot
4agedub
Post by 4agedub »
Scat dual springs. I think anything from 6000rpm you need the double or high duty springs. Also if you are running big heavy valves then you do need them.
4agedub
Post by 4agedub »
We had some issues at the phakisa race. Stripped the engine and found this
4agedub
Post by 4agedub »
The cam follower broke... why I do not know yet. Maybe it was over revving. Went to 8000rpm once on a down shift.
What make of lifter?
4agedub
Post by 4agedub »
EMPI wide head
