Just ordered myself some parts on summit racing from the states... (just don't tell my wife
Here's what I ordered:
4x 420cc Edelbrock fuel injectors. I will use these as my primary injectors and my current 310cc injectors for the methanol injection
8x Special ngk spark plugs for the CB heads. The CB heads use 12mm spark plugs and not normal 14mm
1x Turbo heat shield. This shield goes onto the turbo exhaust housing to keep away the heat from the compressor side.
1x Turbonetics Raptor blow off valve to keep the turbo happy and make that nice "whooosh" sound
1x Turbonetics T3/T4 turbo. Part number TNT-11025. T04e compressor housing with a .48 exhaust housing just like the doctor prescribed. This turbo is matched perfect for 10psi boost and will handle the 7000rpm limit of the engine.
1x Oil drain flange and oil inlet flange to supply the turbo's bearing with some lube
1x Turbonetics evolution dump valve to keep the turbo on 7psi for low boost and 10psi for medium boost and 16psi for racing those gt3 porsches.
Whell, that's all for tonight folks. My parts should be landing on the 30th of this month. As soon as it lands I will take some pics.
By then I better have a good excuse when the wife looks at my credit card statement
