4agedub
Been thanked: 13 times
Re: My Type 1 turbo circuit racer (update pg43)
Post by 4agedub »
thanks
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
4agedub
Post by 4agedub »
Over the weekend quickly fixed the oil leak... the idiot that installed the flywheel [aka me] forgot about the flywheel o ring.
Put the engine back onto the stand, all good now. :)
4agedub
Post by 4agedub »
I've wanted to make a front splitter / bumper for some time now to fit my race bug... a friend of mine gave me a donor bumper this weekend from a BMW e46 m3 race car
It needs a lot of trimming, but will look good when done :D
4agedub
Post by 4agedub »
Retrobug
Has thanked: 15 times
Been thanked: 32 times
Post by Retrobug »
Going to look mean when the spoiler is done! 8)
4agedub
Post by 4agedub »
Cylinder heads are now re-torqued and valve clearances set.
Started making fuel rail brackets last night
Nice. I see you have DICE throttles.
Please do me a favour. Can you compare them to an IDF and tell me how much shorter they are? Last time I spoke to Dave, a few years back, I think he said 40mm shorter.
4agedub
Post by 4agedub »
They are pretty much the same length as IDF's.... but will check tonight
4agedub
Post by 4agedub »
The dice throttle is 87mm from top to bottom base.
We decided to sort out some of our junk last night... funny how you buy stuff because you forgot what you already have. I think we have enough intake manifolds :wink:
This is the carburetor cabinet
One set of 40idf, one set of 44idf and one set of solex 40p11 in storage.
4agedub wrote:The dice throttle is 87mm from top to bottom base.
So true, worst is when you know you have it but can't find it when you needed and stumble onto it when you not looking. LOL.
4agedub
Post by 4agedub »
Yip, I bought a 46mm cromoly flywheel nut about a month ago for my turbo engine, last night found three while cleaning up. One was still brand new. What a way to waste R800
Or after you bought it again...
Thanks Louis
That make them 30mm shorter than the IDF
4agedub
Post by 4agedub »
I got a full set of widened fiberglass fenders this weekend for the race beetle. Before we start trimming the bumper it might be best to bolt on the wide fenders and trim according to those. I think the beetle will look real mean with a wider track... and make space for some wider rubber. Right now it's got 225/50/15" all round, maybe we can go for 10" wide all round
4agedub
Post by 4agedub »
Some progress.
Exhaust manifold and down pipe done. Lambda and EGT bung also installed
