Page 49 of 55
Posted: Thu Feb 27, 2014 5:53 pm
by eben
I've found the body for your next race car... :tic:
Posted: Fri Feb 28, 2014 8:06 am
by 4agedub
Some one has done it already. Ron Lummus racing beetle :D
Tubular chassis with fiberglass shell.
Posted: Fri Feb 28, 2014 10:12 am
by eben
Nice. I actually don't think the newest of the new shapes looks too bad. I digress.... awesome build you have. :)
Posted: Tue Mar 04, 2014 8:18 am
by 4agedub
Throttle linkage is sorted. I was kind of out of ideas on what exactly to do. My dad took one look at it and made a quick plan that works... :)
I'll take some pics tonight.
Posted: Wed Mar 05, 2014 8:39 am
by 4agedub
Here's the linkage mods
Posted: Wed Mar 05, 2014 8:45 am
by 4agedub
I started on the intercooler and oil cooler water sprayers last night. Got some 0.3mm misting nozzles like what they use on patios etc... so they are mainly there to cool the air and not really spray a lot of water. I would like to keep to 5lt max of water on board to save weight with two pumps... one for the oil cooler and one for the intercooler
Posted: Wed Mar 05, 2014 11:26 am
by JamesD
Very nice! are you going to have a filter in that system since those nozzles are so fine?
Posted: Wed Mar 05, 2014 11:52 am
by 4agedub
Yes, a normal carburetor plastic filter works good even with water
Posted: Thu Mar 06, 2014 7:56 am
by 4agedub
Oil cooler spray bar done
Ram tubes installed into throttle bodies
Posted: Thu Mar 06, 2014 8:09 am
by JamesD
4agedub wrote:Oil cooler spray bar done
A ring main might have been better here since it would have given a more even pressure distribution to the spray nozzles and hence a more even spray from all four. Unless your pressure is high enough to not see any noticeable pressure drops after each nozzle?
Also why did you not stagger their placement? might have given greater coverage?
Looks very nicely made, wish my welding was that good!
Posted: Thu Mar 06, 2014 8:19 am
by 4agedub
A windscreen washer pump is capable of supplying 1.5 bar pressure with the four nozzles and maintaining it. So I think it'll be fine. The nozzles face into the airflow and not really directly onto the cooler, the spray pattern is pretty wide as well... but yes I did not even think of staggering the placement :)
Some time back we did an install on a bmw race car with the same nozzles... probably around 20 on one car. On the radiator, intercooler, oil coolers and brake ducts. On that one we used a fuel injection fuel pump and bled it off at 3 bar. :) Works excellent. The pump does not like the water though, a water meth 3 bar pump might be better.
My ally welding sucks. Stainless and mild steel I'm ok, but ally.... if the ally is not 100% clean or the sun & moon is not aligned then it stuffs me around. :) Maybe I just need more practice.
Posted: Thu Mar 06, 2014 2:34 pm
by beetlefanatic
What size fan are you using on the intercooler?
I need an 8" fan but can only seem to find 10" fans.
Posted: Thu Mar 06, 2014 2:39 pm
by 4agedub
I think it is around 8". Got it with a EMPI oil cooler some time ago
Posted: Thu Mar 06, 2014 4:04 pm
by JamesD
http://www.ventura.co.za/wcontact.php
Get hold of these guys @beetlefanatic . This was where I got my oil cooler and fan and I think it was 8" as well.
http://www.hot4cold.co.za
Or you could try these guys...
Posted: Thu Mar 06, 2014 4:10 pm
by beetlefanatic
Thanks James.
