So, I finally have my drivers license!!!
This means that I need a serious kick in the you know where to get the blue beast running because I can drive it legally now
As it stands, the rear valance has been filled with body filler. It needs to be flatted and shaped, then will be sprayed matt black. This is just a temporary measure, the rear valance will be replaced with a fresh one when it can be found.
I have also sourced another rear decklid from Beetlepower. It just needs a bit of welding in the corners, but that is being taken care of and will also be sprayed matt black, as per the plans in the first post of this thread.
In the meanwhile, I have ripped out all the wiring from under the front bonnet and dash area. The wiring was in a seriously hacked state, so the best plan is to start afresh. I have most of the wires from that Variant that I stripped (that car was most definitely worth all the stress) so that will be used...
Pictures to follow. Now I'm seriously amped to have a running ACVW
