A bus named Grace
stew 89
Has thanked: 12 times
Re: A bus named Grace
Post by stew 89 »
I also thought it could be that but non of the valves are jammed open. the valve its self appears to be fine. Could the push rod bend? or compress?
stew 89
Post by stew 89 »
Please Guys
I realy need some help on this one. I dont have photos to show you so ill do my best to explane. The in let rocer arm has about 1 cm of play. How ever the valve is siting at the same hight as the other valves. so this means that the play is in the direction of the Push rod. so my thought is that the problem lies with ether the cam, the cam folower or the Push rod? Has this ever hapend befor to any one else?
yep... drove me up the wall - mine was a broken cam follower
stew 89
Post by stew 89 »
So the update is tha she is back at the mach to be opened and for the extent of the problem to be evaluated.... :roll: :cry:
Drusky
Has thanked: 77 times
Been thanked: 15 times
Post by Drusky »
I feel for you boet :cry:
stew 89
Post by stew 89 »
Thanks Drusky its kak but thats the way the cookie crumbles.
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
I had a similar problem with my type4 motor and turned out to be a cam follower that got stuck and grinded the cam lobe and follower to half the lenth !
So waiting for new followers and cam from scat hope its not that bad in your case man.
stew 89
Post by stew 89 »
Split fan the chance is quite high that that is the problem.
Stew
splitfan
Post by splitfan »
Damm man at least if thats the case you have a excuse to "upgrade" the cam :drunks:
stew 89
Post by stew 89 »
Thats true the only problem is that it was a newly re profiled cam. the so called "newly rebuilt" motor had not even run for more than 2 hours total.
stew 89
Post by stew 89 »
Well the motor is back in JHB at the engineers they started on it today. lets hold thumbs its not completely KAK!
lowlight
Post by lowlight »
Any news on the bus.(spotted voortrekkerstraat?)
stew 89
Post by stew 89 »
Hell. hows it Lowlight.
Man she is almost done the interior is done and all the other bits and peaces. all that remains is to get her started after her 2nd engine rebuild in a year. T Mechanic a trusted scrood me so that made a small setback. I tell you what its just easier to do things your self. When i have time ill post picks work has just been so mad that i have not had time to think.
Shot Stew
stew 89
Post by stew 89 »
Hello every one. All the best for 2011!
Just a quick update. The motor is out again as the same thing has happened again. I have dissuaded to take a crack at it my self (what can i loose) strip the thing down to the block. had a peek inside only to find. that the cam and followers have chowed one another again. after only 120km.... this time I'm going for new parts. no more second had things.
Will keep you posted...
Recently had some issues with cams and followers as well, and these were all new HP parts, dudes I know have also been having issues, what I have found is: poor quality or spec of new parts, (for engine bits) stay away from anything with China on it. The second thing and probably the most important is the oil used during break in as well as what is in the sump after that.
Oil has changed a lot in the last few years due to regulations & to save newer co2 sensors as well as catalitic converters.
Firstly the zinc content which is very important lubricating agent has been reduced big time in all oils you get over the counter, do a search you will be shocked at the reduction of Zink, also stay away from full synthetics or anything with detergents, it kills our old fossil motors, quick.
