KLASSIC FAB SOUTH AFRICA : New Products released !!
- splitbusahollic
- Facebook: vintage kombi
- Has thanked: 87 times
- Been thanked: 54 times
Re: KLASSIC FAB SOUTH AFRICA
have emailed the boss....will let you know Stew.
vintage kombi.co.za (Website)
vintage kombi on Facebook
- splitbusahollic
stew 89 wrote:What would the price on KF-BW214 (the bay window section under windscreen) be?
Stu, this panel will cost you around R 1980.00 plus R300 delivery to you = R2280 all incl.
i have calculated this at a Rand /Dollar rate of R8.5 should that change then i will need to adjust the price.
hope this helps.
- stew 89
- What model do you have?: kombi
- Has thanked: 12 times
Wow that is very reasonable. We shall talk in the not to distant future
Thank you for a awesome service.
- splitbusahollic
Here is a bit of info regarding pillars on a split bus.
Orange = A pillars
Yellow = B pillars
Green = C pillars
Blue = inner rocker
passenger side B pillar
Drivers side B pillar
Long side re-enforcement pillars
inner pillar attachment to inner rocker.
Pink = Top Hats
Purple = i beams
inner dogleg
inner rocker attachment to rear wheel well.
i hope this helps.
Orange = A pillars
Yellow = B pillars
Green = C pillars
Blue = inner rocker
Pink = Top Hats
Purple = i beams
inner dogleg
i hope this helps.
- splitbusahollic
I have panels in stock if you need !!
pm me or give me a call....
FUNKY GREEN STUFF.
FUNKY GREEN STUFF.
Warwick-Lowlight
- Been thanked: 14 times
Funky Green stuff - Yeah
Soon the end of the month
Will be giving a call soon
Maybe we can get some pics going from my side seeing as someone else does not want to share
- splitbusahollic
i agree Warwick !!Warwick-Lowlight wrote:Maybe we can get some pics going from my side seeing as someone else does not want to share
some one is holding back on us !!
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
Thanks for those photos of the bus under restoration, these help a lot for reference.
Is this the camper that Dolf bought in George a few year back ? He certainly does'nt do anything in half measures
What has been replaced on that body - I mean that bus was a rusted hulk ? Does he have any pics of it after all the rust was cut out ?
- splitbusahollic
Rear Corner Anyone ?....some lower "A" pillar sections, maybe some Jack points ?
@ Paul : this rear corner was in fact for that bus !!
Warwick-Lowlight
Good morning Uncle
You been fishing or are you
We've been catching some yellow tails and fins down south
Will give you a call
- jolas
Eish I did'nt order that ! Are you talking about my '59 ? Have you got my last order ready old chap
Do you do Valiant panels
- splitbusahollic
would any one need panels at the George Show ??
let me know ....stock flying out at the moment ....!
the Klassic Fab website is up and running....check it out :
http://www.vintagekombi.com/ClassicFAB.html
double click on the pic and it will enlarge so you can read the part no and description.
there is also a price list....use the rand dollar exchange rate eg. 8.90 at the moment, add 30% duties and 14%vat ....then add R80/kg freight..i will compile a list of weights..that should give you the price per panel excl. shipping to you.
i do have the Exclusivity for Southern Africa, so please don't contact Gerson direct he will just forward you order to me.
these are some of the common panels that we've sold up to date...
KF14 lower A pillar above the first hinge 1.8KG R 1463
KF38 Lower inner valance 3KG R 2072
KF43 Lower outer valance 2.6KG R 1233
KF49 lower nose panel 8" 3KG R 1340
KF59 Headlight buket support panel 2.7KG R 3513
KF141 comlpete front floor 6.2KG 55/59 R 5625 , 60/64 R 4893 , 65/67 R 4534
KF159 front floor repair section right side 1.9KG R 1471
KF161 Front floor repair section left side RHD bus 1.7KG R 1455
KF216 lower windshield repair panel 8" 850G R 2119
KF218 lower windshield repair panel 12" 1KG R 2278
KF 291 Dogleg lower front repair panel outer 750G R 650
KF293 Dogleg lower front repair panel inner 750G R 935
KF 341 Lower "B" pillar above first hinge with dogleg close out 900G R 1097
KF464 "C" pillar above the first hinge bus 500G R 919
KF486 lower re-enforcement pillar 12" 200G R 530
KF492 Carg door rocker complete (inner and outer) 2.5KG R 1080
KF 511 outriggers 700G R 466
KF522 middle top hat section 1.5KG R 780
KF523 rear top hat with close out panel 2.2KG R 835
KF531 Inner Rocker 1.6KG R 640
KF535 Front jack point 600G R 862
KF564 lower cargo door repair skin 6" 750G R 350
KF565 lower carg door repair frame 6" 850G R 507
KF602 Cargo floor RHD with seats complete 28.5KG R 11 800 ( comes with all the correct pressings in a two piece set) i can work a small discount on this item.
KF698 Cargo floor repair section with seats 5.2KG R 2030
KF896 Complete bellypan set 20.5KG R 10390
KF918 short side rocker 6" 600G R 560
KF919 Short side rocker 14" 1.5KG R 850
KF 942 long side rocker 6" 2.5KG R 1152
KF943 long side rocker 14" 5KG R 1720
KF1295 Rear corner 8" bus 1KG R 1400
prices don't include shipping to customer.
prices subject to change without notice. subject to rand dollar exchange rate at time of import.
i will add to the list as time goes by.....
i hope this helps....if you not sure then PM me.
thanks
thanks
Last edited by splitbusahollic on Sun Apr 27, 2014 12:12 pm, edited 3 times in total.
Hi Can you pls Pm me some prices on Samba window inserts outer and the inner panels pls 8xsamba window panels
- Barry
- Single Port
- Been thanked: 12 times
Hi Jacques
Seems like the new site is not 100%. I also can't find pricing - please give a link to the pricelist if it is up.
I have asked before, but surely being able to quote a Rand price shouldn't be that hard? Plug in your values - cost, exchange rate, weight etc into an Excel spreadsheet and you'll have the number in seconds. I am sure most guys needing these panels are prepared to jump through hoops as they don't have other options, but I'd still like to think having an actual price at hand would potentially increase sales?
Barry
- splitbusahollic
just click on the home page and the price list is on the right hand bottom.Barry wrote:Seems like the new site is not 100%. I also can't find pricing - please give a link to the pricelist if it is up.
i will add the Rand pricing to the weight list so long....
i am busy with a website and that will have all the rand prices on.
