Warwicks Split
splitbusahollic
Facebook: vintage kombi
Has thanked: 87 times
Re: Warwicks Split
Post by splitbusahollic »
i think realistically we will see all three of you at George 2013 !! that would be cool !! 8)
vintage kombi.co.za (Website)
vintage kombi on Facebook
Warwick-Lowlight
Re: Warwicks Split
Post by Warwick-Lowlight »
Now lets see whos paying attention :twisted:
By lowlightwarwick at 2012-08-17
:P :wink: :lol:
Re: Warwicks Split
:lol: I'll have it if you don"t want it ! Looks like it is off an old lorry !!!
(nice patina :twisted: )
Warwick-Lowlight
Re: Warwicks Split
Paul I keep one spare
The Patinas are pilling up
Warwick-Lowlight
Re: Warwicks Split
Well this morning thought I might drain the oil from the gearbox
Came out all goooooey and there were a few metal bits :evil:
So went in a bit further and found this
Cage on the gearside bearing had lost a section
Dont know if this was from the bolt that had sheared or otherway round
Further inspection showed a little surface damage on the inside where the loose bolt had been rolling around
Luckely no damage to the teeth
Seems Gear side bearing is shot so will replace that
the other side will probably be done as the whole lot is open
Also found what looks like a date engraved on the crown wheel think thats the gears name
Possibly an fitter back in the day just doing some graffitti ????
Loose bits - not supposed to be here
Where the bolt came from
Inside of the box also coated in a dark layer of oil - seems there might have been some heat somewhere along the line
well the joys of doing a restoration
never know what suprise will jump at you when you next hit the workshopppe
:hangloose:
Warwick-Lowlight
Re: Warwicks Split
Sorted out driver side handle and lock as the old one was smoked
A bit of a fidly kinda job
First realised how old I was getting as it took me about 5 minutes to find the location of the grub screw
Note to others doing this job dont hit out the bottom pin as it is the locking pin - you will damage the barrel
Main pin that hold the handle and holder together knocked out
Grub screw removed and barrel out
Key into new barrel
File away some of the locking teeth
Test fit for smooth operation
Lube
Grub screw back in
Minor adjustments to the new handle
Assemble
Drive back main pin
Thre you go one new door handle that locks
By lowlightwarwick at 2012-08-18
Warwick-Lowlight
Re: Warwicks Split
Well seemed today was national shed cleaning day - not even the 1st of Spring :lol:
Got the buddies together
By lowlightwarwick at 2012-08-20
boxed all the box bits
cleaned the box
Jes Captain Jeyes at work for better than that doff movie on Mnet last night - Captain Wanna be more like it
Just waiting for the beeg bearings - should be here tommorrow then I can put the whole lot back together again
:hangloose:
Warwick-Lowlight
Re: Warwicks Split
Hows about this one it even comes with a dash :lol:
By lowlightwarwick at 2012-08-21
Warwick-Lowlight
Re: Warwicks Split
Well the wheels on the bus are supposed to round and round
Gearbox blues continue
If only it was just that broken off nut and bearings that needed attention :evil:
Got the new bearings and put them in
New 3/8ths bolt and drilled a hole in it for the wire
Bought a torque rench and set the bolts to 6mkg
Started to wire up with some welding wire - clockwise set to keep the tension
That was yesterday
So this morning - removed the oil seal
This took longer than expected but got it out - definate heat damage as it was baked
With all the twisting and turning to get the seal out I heard a rattle in the danger area of the box
Took out the drain plug and had a feel in there with my finger
A little gritty - thats not good
close up plug and put in some power parrafin and wash around for a bit
Get my wash backet and drain the box
Turns out the gritty is alot of metal - felt like a gold panner but for the wrong reasons
Still a rattle so some more shaking and fingering and then the shit hits the fan
These 2 pieces of obiously iside stuff are now outside
Can see that the one on the left has a fair amount of wear
Seems I have found the reason for the bus being parked under the tree those years ago
Bugger will be getting a Pm
So hopes of mechanical first will be paused for a bit
Seems the rotissarie for the Manx will be next so I can crack on with the repairs to the pan
Watch this space
splitbusahollic
Re: Warwicks Split
that's bad news ! :(
i 'm sure Pierre can help.....maybe some body work so long ?
Warwick-Lowlight
Re: Warwicks Split
Thats the plan
Just a bit of practise o the Manx pan
Has thanked: 45 times
Been thanked: 208 times
Re: Warwicks Split
Remember that after replacement of those bearings the crownwheel alignment need to be checked and shims adjusted/changed as required.
Warwick-Lowlight
Re: Warwicks Split
Got that just trying to figure out the maths to match up
Warwick-Lowlight
Re: Warwicks Split
Took the outer cover off to get abetter look as the gear shift was stuck
Everything in Neutral and free
Engage left top lever 3rd /4th ?? all fine engage neutral and engage back to neutral all free
centre lever feels a bit tight but does go in and out but then when its back in neutral its not
Need to engage 3rd or 4th then back to neutral then all is loose again
Hopeping that the bits are from the selector
Thats the first bit -the second will be where to find another one
By lowlightwarwick at 2012-08-22
Re: Warwicks Split
Seeing that you are a technical guy, and as the box's condition is sort of...you know...,
And you are already that far.
Why not loosen the pinion bearing and separate the box for inspection. Remember to carefully mark everything where necessary and keep note of shims. Then show us the pictures.
