I've finally got a KG. This is the one that used to belong to GSI31099.
looks awesome, great choice in colourJNP wrote:Thanks for the advice. Bug and KG brakes are the same I thin.
Some pics after the first spray. There are still a few issues to sort out before a final spray. The colour should be more or less the same though.
http://img37.imageshack.us/i/imgp0048s.jpg/
http://img194.imageshack.us/i/imgp0046m.jpg/
http://img17.imageshack.us/i/imgp0047v.jpg/
Unless you're putting on a rim where the dish is towards the outside of the rim, i.e. you needs an adapter to correct the wheel track, you should be able to machine the new stud pattern into the drum, no?JNP wrote:Thanks for the info. My reason to change back to disks was to avoid adjustments.
Decided to leave the back as drums and fit converters to get me to the 5X130 PCD I require for the wheels.
The aim now is to get COR done and get her home.
