How to: head unit and splits instal without an amp.
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Wsup guys. So a bud with a jetta has a new head unit and a set of targa splits, now we need to hook these up BUT without an amplifier. The head unit can be hooked up easy. But how do we wire the splits? Thanks
Re: How to: head unit and splits instal without an amp.
What model Jetta is it?
- bugspray
- Floorpan
It should have wires in the car for a radio.The speakers,depending on size will fit in the existing speaker holders in the doors.
- bugspray
- Floorpan
Yeah got that sorted. Its more the wiring up, like how do we source power for the x-over, how do we instal the split system, it didnt come with instructions.
The cross overs can be connected the same as when you connect up an amp.
L and R into the x-over,and the connect the splits to the out port.But that said,why would you want to use x-overs.The Head unit already does that work for you.Normally an amp requires a x-over.
- bugspray
- Floorpan
- karmakoma
I was wondering if they are passive or active crossovers. Glad to see they were passives. Way easier to hook up.
Basically what Chris said, just add the tweeters. But you got it sorted, so cool.
- bugspray
- Floorpan
Shott guys. While we here. How would a 3way split system be wired up, outta curiosity??
- karmakoma
Depends again on whether is passive or active crossovers, and how you want to amplify each portion. If everything else stays the same as the scenario above, there would still be cable from the headunit to the crossover, and from there to Tweeters, mids, and woofers. Without an amp, you would be wasting your money though.
- karmakoma
Just another note, the reason you would want to split the sound into three, is so that the clarity is increased, as you have a "specialist" speaker for your lows, mids and highs. The more speakers your system has though, the more power it requires, and hence the reason your average headunit won't be able to power it all properly, especially if you up the volume, causing distortion, and WORSE sound. I'll qualify all this with a "Thats just from my experience".
- bugspray
- Floorpan
Swt. I understand sound, but have never seen a 3way set up. Does it come with an active x-over? hows the x-over and speakers wired? is it a 3way x-over also? i know an amp is needed, but the above scenario is only till the amp is pickdup. A 3way split system is ultimate sq staging imo. Prices are scary tho.
- karmakoma
I am sure you get them in passive and active. Although I suspect active is probably most common when you start going this high end.
There are several different types, but here is a pic of one to give you some idea: http://www.autostyle.co.za/prodview.php ... dstr=&str=
On this one you can see that you can still adjust the crossover frequencies for each range. Required imho as each car has different interior acoustic characteristics.
