Can someone help me with some measurements please?
Post by 1972 »
OK am busy trying to see if i can do something to solve alot of problems....
These are the measurements I will be needing all from the front beam..
The inner diamiter of the tubes.
And the lenght of the beam from end to end for now..
Please and thank you :mrgreen:
Re: Can someone help me with some measurements please?
Post by 1972 »
And if someone has the outer diametre of the tubes it would help alot thanks
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
od 52mm
id 45mm
Width i will get tommorrow
Post by 1972 »
Thanks IMPI, I dont know if this is correct but have a measurement on these drawings of 87cm?
(That is from end to end)
