"The advice I give everybody (and am finally starting to listen to myself!!) is to get yourself into a DRIVING project - and then KEEP it on the road, doing nothing bigger at a time than can be tackled in one weekend.
That helps the budget, keeps your motivation going, allows your to mingle and pick up tips and ideas from fellow enthusiasts etc.
Not to mention that is how it was done "back in the day" - a car was never in primer longer than it took to scrape the money together and do the work, but in the meantime it was (for the most part) the guys only vehicle. That also helps you to make sure it is reliable, and to learn the basics you'll need when you breakdown on those long road trips.....wouldn't be a roadtrip without breakdowns!"
This is the lesson that I learnt the hard way
