hey all.
my bug has 2 pioneer 6x9's in the back and a piece-o-shit radio,
im looking to go for something like: Sony Xplode frontloader
Sony Xplode 6x9's in the back
a amp
a sub in the backseat wall at the bottom.
and then i want to put some speakers in the front. don't know what and where?
any idea's on where to mount these. and what speakers to use?
Front mounts
- Klippie
Front mounts
!!!!enough torque to tenderize an elephant!!!!
“Much more of a hoot to drive than you might imagine. Think of it if you like, as a librarian with a G-string under her tweed pants. I do, and it helps.”
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Re: Front mounts
You can use, any size speakers you want in a kick panel mount. check out faraads thread in the ice section its been covered there, you will have to cut the dash in order to fit the sony hu in the exsisting spot.
- JamesD
- Been thanked: 20 times
Re: Front mounts
From fastest to slowest:
'75 SP 1600 with a few mods
- Klippie
Re: Front mounts
i curently have a frontloader installed in the centre of the dashboard. went through that thread. im not to keen on cutting into the bodywork at all. would be great to mount them in the doors. i have some idea's but that means redoing the hole doorpannel. thought about maby building a wooden housing of some sort and mount it to the bottom of the dash.
- bugspray
- Floorpan
Re: Front mounts
With kick panels you dont have to cut anything. just get a panel made from fibreglass and wood. check out jmvws thread in my ride. he has awesome ones no cutting done. and great staging.
- Klippie
Re: Front mounts
Got the radio, got the 6x9's, and wired up the extra 6x9's under the seat, just for fun.
Going to save up for sub, amp, and jmvw's setup lol
