Soda Blasting paint stripping
Skipper
- What model do you have?: Combi
Hi all, I'm new here, I saw a thread about someone wanting info on soda blasting, well I own S A Soda Blasting here in Cape Town and we do paint/rust/grease etc stripping of classic vehicles at your own premisses/workshop etc.
So if anyone needs more info or help PM me or call 082 492 2340
http://www.sasodablasting.co.za" onclick="window.open(this.href);return false;
http://www.fluidcorrosioncontrol.co.za" onclick="window.open(this.href);return false;
http://www.rustbullet.com" onclick="window.open(this.href);return false;
- dsan
- Twin Port
Re: Soda Blasting paint stripping
Fancy driving up to Durbs? I have a SC/Van that will need stripping?
Daniel
Damn pity that you not in Gauteng!
- dsan
- Twin Port
Sorry to hijack your thread, but it's inline with the topic.
Is there no company in JHB who can safely strip a van from all the crap/paint/filler/paper/chicken wire?
Daniel
Skipper
Sorry but I am only doing Cape Town area at the moment, am hoping to set up in JHB next year around March/April, the set up costs for this stuff is +- 250K a rig
- 1972
What would it cost to soda blast a vw bus? plus,minus
Skipper
If its just the outside +- R2400, for the complete vehicle including inside and chassis and engine, wheels i.e. everything then its +- R6000.1972 wrote:What would it cost to soda blast a vw bus? plus,minus
The outside we can do without removing windows and rubber seals etc as it will not damage glass or rubber, in fact it will remove paint from glass with no marking on the glass
- 1972
I think i have emailed you guys before and asked if you had a JHB branch
Ok if i had to put the car onto a trailer and come down to CPT how long before it will start to rust after been blasted or do you spray a primer once you done?
Skipper
Soda blasting up's the Ph of metal so it will last a couple of weeks before any flash rust develops, I also sell Fluid Film, this is an anti-corrosion and lubrication spray/liquid which stops any metal from rusting for up to two years, its none toxic and made from Lanolin, in fact you could strip a van then coat it with FF and leave it outside by the sea for two years with no ill effects, check out my site http://www.fluidcorrosioncontrol.co.za for more info1972 wrote:I think i have emailed you guys before and asked if you had a JHB branch![]()
- Barry
- Single Port
- Been thanked: 12 times
There's an interesting current thread on metalmeet.com about paint adhesion problems after soda blasting. Seems to be widespread consensus.
Any insights Skipper?
Barry
Skipper
Soda raises the metals Ph which inhibits corrosion for a short while, before you repaint the metal will need a thorough wash down to remove all soda particles, problem then solvedBarry wrote:There's an interesting current thread on metalmeet.com about paint adhesion problems after soda blasting. Seems to be widespread consensus.
- Dutch_Diver
I have 3 roof racks that I want stripped and then powercoated.....2 for a beetle and 1 full length one for a bus. Can you strip them? Do you also know of a powercoater who can handle big stuff in Cape Town area?
- Barry
- Single Port
Dutch you can take those to Aspect Powder Coating in Strand. Speak to William.
Are you going to galvanise or zinc plate? - powder coating doesn't give corrosion protection.
Barry
- Dutch_Diver
Thanks Barry.....what's better Galv or Zinc? I hadn't realised...I thought PC covered it all..... Need to get them all done asap!
Do you have the telephone number? Are they on Main Road, Strand?
