Got and extra 2l block as can see lying inside o the car.
In need of couple of things for it still but should be running end of next month if every thing goes to plan and can get the parts needed.
Urgently needed is the wire between the dissy and the coil and the linkages between carbs photo of connector included
It has 2 sidedrafts on but want the standerd carbs.
