I'm thinking of using a tie-rod end frt susp. on my '63 instead of the king and linkpin setup.
Anyone know if it is a direct swap, or not so easy?
Swapping linkpin torsion bars for tie rod end tbs.
- davetapson
- What model do you have?: Type 1's '63 and '66
- Facebook: www.facebook.com/davetapson
- Tom Bishop
- Single Port
- Been thanked: 5 times
Re: Swapping linkpin torsion bars for tie rod end tbs.
If its a beetle and you refering to a Ball joint suspension, its not a straight swap.
The lower torsion bar housing is thicker and the two torsion bar housings are further vertically appart.
I have seen the uprights cut to bring the 2 housing to the same distance as the K&L suspension.
- BUGGOFF
- Pushrod
I also found that out the hard way. easiest is to swop the pans.
- davetapson
Any modifications need to be made to the body / pan if I swap pans?
