Swapping linkpin torsion bars for tie rod end tbs.
Posted: Sat Apr 24, 2010 1:22 pm
by davetapson
I'm thinking of using a tie-rod end frt susp. on my '63 instead of the king and linkpin setup.
Anyone know if it is a direct swap, or not so easy?
Re: Swapping linkpin torsion bars for tie rod end tbs.
Posted: Sat Apr 24, 2010 5:29 pm
by Tom Bishop
If its a beetle and you refering to a Ball joint suspension, its not a straight swap.
The lower torsion bar housing is thicker and the two torsion bar housings are further vertically appart.
I have seen the uprights cut to bring the 2 housing to the same distance as the K&L suspension.
Posted: Sat Apr 24, 2010 6:34 pm
by BUGGOFF
I also found that out the hard way. easiest is to swop the pans.
Posted: Sat Apr 24, 2010 9:22 pm
by davetapson
Any modifications need to be made to the body / pan if I swap pans?
