I drove two cars home this weekend!
Had a first time experience this weekend; I drove two cars home at the same time! 8) But first let's catch up on the story.
I've been doing quite a bit of mechanical work on the 56 oval since I got it home. First job was to fix the oil leak after it dumped all its oil on the road when I drove it home for the first time. I got an original flywheel oil seal from calooker (you da man Rui!!!) and pulled the engine a couple of weeks back. Once I got the flywheel off the problem was immediately apparent: the last time the seal was changed they had used the wrong seal, and the OD was obviously a little loose. No problem, someone het 'n plan gemaak ... they shellacked the seal into the case. :roll: The 60km drive home was obviously too much and the seal popped out.
After I replaced the seal and the engine was back in the car, I noticed a fuel smell in the engine compartment, so I didn't drive the car until this past weekend when I checked it out again. I also took the opportunity to replace the missing towel rails and overriders that had originally been fitted (56 was the first year for this option!). When I checked the fuel smell out, I discovered that the steel fuel line had worn through where it goes through the front (FIF) engine tin, as there was no grommet. This is a serious fire hazard on ACVWs and I suggest you check yours right now!
So I replaced the steel fuel line with a spare from my stash (it's the old style that screws into the fuel pump, no rubber lines). After that the damned car wouldn't start. I eventually decided it was just an air lock in the pump and figured a push start would sort it out but, by the time the car was at the bottom of the hill it hadn't started. Only then did it occur to me that the replacement fuel line may have been blocked, which I hadn't checked when I installed it. DOH!!! :roll:
So I walked the kilometre back home and fetched some tools and found there wa a wasp's nest in the fuel line. Once I cleaned it out the car fired right up and sat there idling sweetly. So I took it for a long test drive. DOH again!!! About 3km from home, in Auckland Park, the car died again after bits of wasp's nest clogged up the carb. So I walked home again to fetch more tools and drove back in my Mercedes. I cleaned the carb out in a jiffy and the beetle was running sweetly again, but now I was 3km from home with two cars. So I drove the beetle 200m and parked it, then walked back to the Mercedes, drove it 100m past the beetle and parked, then walked back to the beetle and repeated the process until I got my ass and both cars back home!
I've ridden two bicycles simultaneously before, but this was the first time I ever drove two cars at the same time. :hangloose:
splitfan
Has thanked: 46 times
Been thanked: 26 times
Re: I drove two cars home this weekend!
Post by splitfan »
Ohh the joy of vintage motoring ! :mrgreen:
joose
What model do you have?: '63 Cal-look Ghia
Post by joose »
haha! great story fig! that must have been quite a sight - seeing a guy driving one car 200 meters, then the next 300! :P Where do you live if Auckland park is 3km away?
GavinHuart
Has thanked: 48 times
Been thanked: 9 times
Post by GavinHuart »
What a neat story! Leap-frogging with cars :lol: Oh do take some pics of your fantastic car with it's newly fitted towel-rails and overriders. I can't get enough of this car!
:lol:
A real Kodak moment.
Eugene
Has thanked: 59 times
Been thanked: 65 times
Post by Eugene »
Doh....if you just drove the one car home, walked back the 3kms and drove that car home, you would have saved yourself about 300m and a lot of time :lol:
Bugandy
Post by Bugandy »
Um.......or driven one car home and gotten lift back to the other one? Or maybe the chance that one would be stolen was the determining factor?
LOL!!! Yes, I didn't fancy leaving either car alone on the street any longer than I had to. It was bad enough walking away from the oval after it died, but I couldn't bring myself to leave it knowing it was running well again.
I live in Brixton, just over the ridge from Auckland Park. Gavin, pics are to come, but first I want to wash and polish the oval, so you'll have to wait. I want to get all the chrome and aluminium trim as shiny as possible to offset the patinaed paint.
vfront
What model do you have?: 1974 Beetle
Post by vfront »
Proper Mastercard moment.
Priceless
Klaus
Post by Klaus »
:D
The Aircooled adventure never ends !
Looking forward to the pictures.
Those pics already sound like they will need to be PG rated.
Oval ragtop, RHD, Patina, mmmmm. Classic Story! :lol:
You should have used one of your life lines ..... :lol: phone a friend :zhelp:
When I was a little boy my dad did something similar when he bought a second car. :D
A few weeks ago while sorting out some issues with my SC I ran out of fuel, didn't have my cell or wallet with me, walked home about 3 km's, jumped on my bicycle with a 5L container and some cash, once the SC was running again threw the bicycle on the back and drove home.
When I collected this SC I rode my bike about 40 km's threw the bike in the back and drove the SC home, after my wife refused to give me a lift to collect it, she thought I didn’t need another ACVW, she just doesn't get it. :(
