I want to have some badges/signs cut from 2.5 mm alu sheet. can anybody assist please. these badges must also be gold anodised afterwards
regards
Laser or similar cutting
- sarel.wagner
- Pushrod
- What model do you have?: T1 x 4, Split SCwide
- Facebook: http://www.facebook.com/sarel.wagner
- Been thanked: 2 times
Re: Laser or similar cutting
These guys are quite close to me, waterjet etc. http://www.kwikwap.co.za/waterjet/wcontact.php
Rgrds
Rgrds
What other people think of you is none of your damn business
- bienie
- What model do you have?: 1961 beetle, Wizzard
Or try Afriqcut 012-811 1205 082 926 1661 http://www.afriqcut.co.za
Speak to Miempie Pietrse
Plot 83 Tiegerpoort Garsfontein Ext
One VW at a time
jmvv
- Been thanked: 24 times
I would go for the waterjet cutting.
I have found that laser cutting causes a little defect in the cutting line where the cut begins. This is caused by the laser heating the material prior to cutting.
- karmakoma
To the guys in the know, in your past experience,do these cutting shops have minimum order/material quantities, IE, will they cut say, 5 badges for me?
KK
KK
- bienie
They will cut small quantity ,but they normally have a minimum charge
One VW at a time
