Towing a beetle
Shella
What model do you have?: '74 1600 Beetle
Towing a beetle
Post by Shella »
Hey guys... How does one tow a beetle without a trailer? I couldn't see an eye or something similiar to attach a tow rope.
splitfan
Has thanked: 46 times
Been thanked: 26 times
Re: Towing a beetle
Post by splitfan »
I would think that a A-frame would be the next best option if no trailer is available.
beetlepower
Twin Port
Been thanked: 29 times
Re: Towing a beetle
Post by beetlepower »
There is a opening covered by a hole in the front valence and another one in the spare wheel well then tie the rope onto the front suspension, or under the car onto the front suspension if you cant get a a frame and the brakes are ok
0828378801
@reubenvn on twitter
Shella
Re: Towing a beetle
Post by Shella »
Perfect! Thanks. I saw the hole you refering to. I thought there'd be an eye there.
ZeroAxe
Drive Train
Re: Towing a beetle
Post by ZeroAxe »
Shella wrote:Perfect! Thanks. I saw the hole you refering to. I thought there'd be an eye there.
Luckily you didnt find an aR$ehole in there :lol:
VW Enthusiast
Re: Towing a beetle
The hole in the front valence and behind the spare is to allow acccess to the inspection panel in the front of the tunnel, so you can replace control cable tubes or fuel line. I wouldn't run a tow cable through there; you have a good chance of damaging paint and bodywork.
The owner's manual shows that you attach a tow cable under the car to the front beam, and at the rear to the lower shock supports. You really should'nt tow with a rope/cable/chain except in an emergency. Get a decent A-frame or, even better, a double axle car trailer.
Bugandy
Re: Towing a beetle
Post by Bugandy »
Any diagrams etc to make a decent A-frame? Please........
JBug
What model do you have?: A few Bugs
Re: Towing a beetle
Post by JBug »
I`ve had a piece of steel laser cut to resemble a bumper braket and welded on an "eye" at the tip. Remove the bumper, bolt this in and use a proper tow-bar....didnt have any issues YET :drunks:
Old Volkswagens never die, they just get lower.
louisvr45
Re: Towing a beetle
Post by louisvr45 »
You can always remove the bumper and leafe the brackets on and attached the rope there. The main idea is the attached it where you can mount it to the 2 longeron beams which is the main chassis without touching/damageing the body work. the front axle lower beam can also be used
JBug
Re: Towing a beetle
Post by JBug »
louisvr45 wrote:You can always remove the bumper and leafe the brackets on and attached the rope there. The main idea is the attached it where you can mount it to the 2 longeron beams which is the main chassis without touching/damageing the body work. the front axle lower beam can also be used
We tried that once and halfway through a turn, the bumper bracket bent onto the apron and fooked it up hence the steel plate. Once bolted its pretty solid.
Been thanked: 21 times
Re: Towing a beetle
Post by Ron&Gill »
fig wrote:The hole in the front valence and behind the spare is to allow acccess to the inspection panel in the front of the tunnel, so you can replace control cable tubes or fuel line. I wouldn't run a tow cable through there; you have a good chance of damaging paint and bodywork.
That access plate is there to replace the gear shift bush and/rod. You need that open to push the gear selector rod out forward. Then you flip the old bush out and put the new little plastic bush into the metal plate under the shifter and pull the well greased selector rod back though the bush and reconnect it to the hockey stick.
Control cables can be replaced without opening that plate (by removing the pedal cluster if need be) and the fuel line can't be replaced. At best you could run a parallel fuel line through the tunnel, but you would not be able to fix it properly (nor get the old one out), and therefore it could rub against the exposed moving clutch hook and cable loop.
But nevertheless, as The Fig points out, you should not tow through that hole. You can simply attach the rope to the front beam off centre, and make sure the driver up front drives like a civilized human being without jerking. My experience has shown the bumper to be strong enough as well if you are careful.
Re: Towing a beetle
Ron&Gill wrote:That access plate is there to replace the gear shift bush and/rod. You need that open to push the gear selector rod out forward. Then you flip the old bush out and put the new little plastic bush into the metal plate under the shifter and pull the well greased selector rod back though the bush and reconnect it to the hockey stick.
Ron's dead right re the shift rod and bushes. I didn't say it was for replacing control cables, I said control cable guide tubes. And you can replace the clutch cable guide tube and fuel line inside the tunnel, but it probably isn't recommended. I did it once when my clutch cable guide tube broke. Pulled the old one out and found it was attached to the fuel line, which trashed the fuel line :oops: . I then replaced both without too much difficulty, but it was a very long time ago, so I don't remember the details.
louisvr45
Re: Towing a beetle
Post by louisvr45 »
Well the bottom of the line is you must attach it to where the car can be pulled or get that wheels transporter where the car's front or rear wheels is on the trailer, if you get your hands ons such a thing
Re: Towing a beetle
Post by Ron&Gill »
Sorry Fig, didn't read it properly. I have seen your problem while cuttin open a tunnel, it's all very clever inside there. Everything is attached to the tunnel walls and eachother, haha!
But on the subject of towing, clearly VW never imagined the Beetle not making it to it's destination under it's own power.
