Stock-length Bugpack 3/4" BALLJOINT 'lowered' sway bar in as-new condition.
The only difference between a non-lowered and lowered bar is the way in which the bar is bent during manufacturing.
A 'lowered' bar allows more clearance when you drop the car, but works exactly the same way as a standard bar.
The bar will be supplied with urethane mounts - you need to supply the type of clamps you prefer to use.
R900
Bay' pedal pans
'68-'70 [ ]
R400
Bay' door lock mechanism
R150
Outer balljoint urethane beam bushings; red (x4)
R250
These are left over from my project.
They are a pair, and were custom made for my bug in error - length issues with my custom suspension setup.
Braided teflon hose with a protective coating. The fittings are standard style, so no issues integrating them.
190mm ea.
R500 - that's less than cost price.
Late bug front indicator - Hella
R100
'66/'67 bug indicator switch (not OEM) - will need repairs as the one 'click' no longer holds the arm in place. R250
Indicator switch 'base' and wiring harness for indicator switch - both I'm unsure of the dates for. neg.
License light housing x 2 neg.
Fuel flap neg.
WolfsburgWest dash repair panel R200
Late bug mirror R100
Gearlever boot - not VW neg.
Interior door handles neg.
Late bug sunvisors R100
WolfsburgWest split bus air vent seal R100
Late bug headlight switch with knob R100
'68-'73 [ ] bug taillight bulb holders and trim rings R50
'68-'71 [ ] bug air vent trim ring (one only) R50
'68+ bug bonnet catch and handle R50
[/quote]
Type 4 twin carb' air filter Offers
K&L bug beam complete from drum to drum R500
DKW lights... (The headlight is from a Junior)
R400 ea.
I have no idea what these are off of (not VW)...
Offers?
JHB.
"Understeer is when you hit the wall with the front of the car, and oversteer, the rear. Hp is how fast you hit the wall, and Torque is how far you take the wall with you."
I will be at CITP at Zwartkops and can bring small items with me.
Else drop me a PM to arrange collection.
Items reserved against your names.
I am interested in the ladt bug mirror for R100, will this fit a 69 beetle?
Also are the window winders sold? if they fit a 69 bug I am also interested.
Hi Zubz,
Yes it will fit a '69.
It has some brown marks on it. I'm not sure what the marks are, nor have I tried to polish them out. The chrome is still good.
Someone has called dibs on the winders shown but I have another set for you. I'll dig them out tonight.
Are you collecting?
Hi Zubz,
Are you collecting?
I can collect, they not very urgent so I can collect at CITP also, when is CITP?
August 1st. Let me know.
No worries. I will only be there for the duration of the morning though.
Short of Karmakoma ( ) I have mobile numbers for all of you and will drop you an SMS on the day.
If my eyes don' t deceive me I spy a Beetle roof rack on the wall??
For Sale?
If not who might have one for sale?
Barrie
Hi Barrie,
Well spotted.
Sorry - none are for sale though.
Cheers, N.
I ask because I need to shift a lot of stuff to get the metal...
Cheers.
