DUAL WEBER 36MM IDF
- What model do you have?: 68 beetle
DUAL WEBER 36MM IDF
Complete carb set: 2x 36mm IDF's, Intake manifolds, Hex bar linkage, and air cleaners.
R4000.00 o.n.c.o
Perfect condition. Still on car if you need to test.
0826349349
R4000.00 o.n.c.o
0826349349
'68 1300 Import Beetle - 1835cc
Re: DUAL WEBER 36MM IDF
Carbs and intakes still available.
R2000.00 urgent sale
0826349349
0826349349
- forcecooled
- Single Port
- Been thanked: 5 times
Thats the first time i have heard of a good complete carb set-up been sold in bits and pieces
You seem to have a lot of Twinchoke downdrafts there - do you have any 40mm sets?
Check your PM
Check your PM
Hi Bill,
Unfortunately only 36's.
PM replied.
PM replied.
Have 1 set left. Carbs only.
And one single Dellorto 36 with intake manifold.
- Junior
- Pushrod
- What model do you have?: Had a 75 + 64 beetle
do you no where I can get intake manifolds from ?
You could check with Rui aka Calooker.
Pretty sure he could supply.
- Junior
- Pushrod
K will speek to him first then contact u
