I read somewhere on this forum that in a beetle due to driving with the windows down, you need a ported sub box?
I have two of these subs in a box that is too large so i need to make a new one...
http://www.sonicelectronix.com/item_872 ... 2.VC2.html
So what i need to know is...the recommended volume is 3 cubic feet? So if i have 2 subs i need 6 ft of volume or can i get away with running a smaller volume?
Sub box queries
Re: Sub box queries
kuckbiscuit wrote:I read somewhere on this forum that in a beetle due to driving with the windows down, you need a ported sub box?
Re: Sub box queries
recommended volume is 3 cu.ft.... for what type of box. Sealed boxes are normally smaller than vented boxes. Those subs you have are 500WRMS each.... stick them into a sealed box and if its not loud enough, then turn up the amp slightly if your amp is able to deliver the power.biscuit wrote: So what i need to know is...the recommended volume is 3 cubic feet? So if i have 2 subs i need 6 ft of volume or can i get away with running a smaller volume?
I have a 4x85WRMS amp driving a 6.5" split up front and a 15" sub in a 70 liter sealed enclosure at the back. Doing 140km/h with the windows down does not stop you from hearing any part of that sound system, you just need to turn up the volume.
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Re: Sub box queries
Bwahahahaha.biscuit wrote:I read somewhere on this forum that in a beetle due to driving with the windows down, you need a ported sub box??
Go with a Sealed box, slightly smaller. You would be fine. What TZ is right. Just don't over crank up the amp.
Sealed enclosures are ore forgiving and I feel better suited to DIY builds...
Show us pics of the process.
Re: Sub box queries
depends which measurement you put the other bits in as....farhaad.sonday wrote:hi![]()
is LXBXH= CUBIC METRE ???
easiest way to calculate it in your head is to use dm (decameter). Where 10cm = 1dm
1dm x 1dm x 1dm = 1 liter
2dm x 2dm x 2dm = 8 liter
1cu.ft = approx 27 liters if I remember correctly
Re: Sub box queries
depends on the sub, some want small boxes, some want larger. Check the spec sheet for your sub and see what it says, then try to stick with that.farhaad.sonday wrote:thanx tz
would it be safe to say 2cu ft for a 10" sealed box
