Disc brake upgrade...
- OD_1
- Oil Seal
- What model do you have?: 1976 1600S
Hi All,
I'm planning on upgrading my brakes to disc brakes. Is this normally done only to the front pair? Can anyone recommend a set of front Disc brakes I could use. Would disc brakes work fine with my 15" Rostyles or do i need to get an adaptor? If so where can i and how much...
Peace
Peace
Re: Disc brake upgrade...
Hi OD1 , yes it is possible to put disks on front and rear . Normally the PCD changes to 4/100 or what ever you want but i have read about guys here on the forum that have put adapters on back to beetle PCD .There are members here that sells the kit as well. Hope fully they will respond to your thread here.If know one responds i will lead you in the right direction.
- OD_1
- Oil Seal
So are you saying that I need to get an adaptor if I want to put disc brakes on? Whats PCD?
Who are the respected brands when it comes to disc brakes???
- dubster
- Been thanked: 3 times
rui use to sell a kit maybe pm him,saw a kit from volkspares for R2500 for the front at ferdi's,dont know if dave rowley has kits..personally i think front disks should be good enough for a stock bug with the rear drums just adjusted properly because a rear kit is over 3k so you have to ask yourself is it worth it on a stock bug?and yes you have to fit either 4x100 mags then or find adapter for the 5 stud to 4x100 for the disks....
1974 1300tp type 1
kart kraft 1717cc buggy
You must get a hub that fits where the drum use to sit , with the bearings inside , that hub you get in different PCD's .According to the PCD of the hub you then fit disks eg , 4/100 , then you fit golf disks like mine . The kit consist off two hubs and two callipre brackets . I think if you want to use standard beetle rims you need to make an adapter . Golf callipre's and disks is the most common ones they use to use , all the parts and rims is freely available.Dave Rowley on the forum can help you with this as well. He sells the kits.OD_1 wrote:So are you saying that I need to get an adaptor if I want to put disc brakes on? Whats PCD?
- Ron&Gill
- Been thanked: 21 times
Don't know if Dave is on the forum, don't think so...
Flat4 racing:
Best to phone him after 5pm on 084 566 0604
Flat4 racing:
- Phillip
- What model do you have?: 72 & 56 oval
Volkspares sells the complete kit for 2500,,,the 19?? Beetle came out with discs,what was the pcd,is a kit like that avail.
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
1967Phillip wrote:Volkspares sells the complete kit for 2500,,,the 19?? Beetle came out with discs,what was the pcd,is a kit like that avail.
130x4
- Been thanked: 98 times
Complete kit for the front R2250 everything new, adapters for the rear R520. 4x 100 pcd
Ie yoy want to retain your stock wheels on the front disk reverse adapters are R1000 extra.
Rui 082 830 6493
Rui 082 830 6493
- Been thanked: 24 times
This is the conversion that I have done on Petrus.
It is essentially the same kit as sold by Volkspares.
It uses Golf 1 discs and calipers with a reverse mount adapter to mount the standard Rostyle wheels.
The adapter moves the front wheels about 1 cm outwards.
It is advisable to use wheel studs mounted in the adapter in stead of the wheel bolts.
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
how hard would it be to get the adapters drilled to a muliti pcd?
And is it avisable to do so?
- JamesD
- Been thanked: 20 times
mine was more like 1 inch... sucks balls when you running 185's.jmvv wrote: The adapter moves the front wheels about 1 cm outwards.
From fastest to slowest:
'75 SP 1600 with a few mods
- Phillip
Hi jmvv,if i may ask,how much did u pay fot that kit,does it bolt on straight away,do u need to build any brackets etc,where did u buy yours, i like that setup
- JamesD
Speak to calooker, thats the same setup he supplies, its a bolt on package that comes with everything...
