Variant's garage sale - Type 3 parts and a few others:
Get your parts here
Variant
What model do you have?: '69 316 & 362
Post by Variant »
Greetings everyone. I have the following parts to offer - please PM or phone if you need more details. The prices are a guide and I am willing to negotiate a little. More parts coming soon.
Air intake - R50
Heater elbows - R50 for both
Headlamp assembly, late Beetle - R100
Early Squareback <'68 rear door with glass - R500
Rear arm rest trim for '68 Squareback - R50 for both pieces
Adriaan
'69 1600L Squareback Automatic
'69 1600A Notchback
Re: Variant's garage sale - Type 3 parts and a few others:
Foglights for me
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
Blitzem ! :shock: That was quick ! Can i please have 2nd dibs on the yellow fogs if blitzboy doesnt take em .
Variant
Post by Variant »
more pics:
Adriaan
'69 1600A Notchback
I'll take the Bougi cords please. Will you be at KKKNK?
beetlepower
Twin Port
Been thanked: 28 times
Post by beetlepower »
Hinge cover and hooter
Ring for me please
0828378801
@reubenvn on twitter
Steering wheel and horn button please.
3rd in line for the yellow spots (ja right!)
Sorry, but the yellow spots are mine and are not for sale :twisted:
Variant
Post by Variant »
bump :)
Adriaan
'69 1600A Notchback
Simon
What model do you have?: 69 squareback
Post by Simon »
can i grab the dual master cyclinder please-will it fit straight onto my 69 squareback?
where would i get it overhauled it cape town>?
shot :D si.
Variant
Post by Variant »
Hi Simon
The MC will bolt straight in but you'll need the tandem fluid reservoir and associated plumbing as well. I can supply the reservoir if you need one. I assume you have the single circuit all drum system at the moment - in that case I'm not sure how well the tandem MC will work as drum brakes need a check valve in the MC to maintain a very slight residual pressure in the cylinders. Calipers apparently don't.
I reccommend 'Brake Super Service' in Woodstock for any brake work. Very reasonably priced and I have always been quite satified with their work. If you prefer I can have the MC overhauled for you. The last one I did worked out to about R650.
Adriaan
'69 1600A Notchback
Simon
Post by Simon »
thanks for the info,helps alot.
sounds like it may be smarter and simpler to simply replace the current single MC i have now-I aint to clued up on these things and dont want to incur issues in the future. what do you think?
is the dual really that much better than the single?
also, the overhaul cost is a little too high for me at the moment :(
where would I find a single MC for the squareback?-do you have any ?
si.
Variant
Post by Variant »
Hi Simon.
What is wrong with your MC? Why not just overhaul it - takes the same 19.05mm kit as a Beetle. (euroseal RK 1.19.03 or RK 7104 X) I can supply that too.
Adriaan
'69 1600A Notchback
Thanks for the steering wheel Variant. Those rear engine mounts for Type 3's look real good as well!
Variant
Post by Variant »
Bump :)
Adriaan
'69 1600A Notchback
