Type 122
Dam
Been thanked: 7 times
Type 122
Post by Dam »
I bought a Type 122 Industrial engine coupled to a Mattei Hydrovane SR45 compressor last year on an auction for the bargain price of R6000.00. Secondhand Hydrovane's go for R25000 or more!
Wednesday morning a big Atlas Copco compressor we use in our brick factory destoyed itself :( . Our standby compressor is used somewhere else, so we decided to see what the VW could do.
By 9 o'clock everything was checked and the VW & Hydrovane coupled to a JC Steele 18H Reel Cutter, working together with a Steele 90 claybrick machine. It worked perfectly :D :hangloose:
Yesterday it ran a full days shift, only being stopped at teatime and lunch to be checked, with no problems to be seen.
Today it is running again, only being stopped for tea & lunch breaks to be checked. Talk about a road trip!
Hobbies & Work can be combined :hangloose: :drunks:
Re: Type 122
Cool story! Thanks for sharing. :hangloose:
Has thanked: 45 times
Been thanked: 208 times
Re: Type 122
Nice!
Looks like that big round thing in front is a cover for a flywheel or ring-gear. The starter is in front, as the hydrovane leaves no space for it at the back? And that thingy above crank pulley must be the speed-governor.
The unit above the gen must be the pressure regulating part of the governor. (Reducing speed if required pressure is reached).
Twin exhausts look like they can be used to push the trolley as well!!
Dam
Re: Type 122
Post by Dam »
Score 3 out of 3, Dawie! :hangloose:
The exhausts look like they can be used, but that hydrovane is moer heavy :lol:
There are 2 handles that go into the frame next to the exhausts to wheel the thing around.
It nice to see how that pressure regulator thing next to the (empty) gennie operates the linkages to the speed governor and then to the carb :D
One of our mechanics remarked: " Kyk hoe trap hy die vet homself " :lol:
Been thanked: 21 times
Re: Type 122
Post by Ron&Gill »
009 dizzie? I think you might get a surprise if you grab those handles after a long day's work... Really nice unit!
Dam
Re: Type 122
Post by Dam »
It says Bosch VJ 4 BR 8 on the dizzie
Dam
Re: Type 122
Post by Dam »
100 hours on the clock :hangloose:
Dam
Re: Type 122
Post by Dam »
Found the right industrial exhaust today, so no more "Wheel barrow" exhausts here! :hangloose:
Thanks Merlin! :D
Merlin
Has thanked: 20 times
Been thanked: 39 times
Re: Type 122
Post by Merlin »
Glad I could help. :)
Re: Type 122
Pics please :)
