rear wheel bearing
- hitlers revenge
- Been thanked: 36 times
rear wheel bearing
Has any body got any hints, tips or ideas as to the easiest removal of a rear wheel bearing on a beetle.
- hitlers revenge
- Merlin
- Has thanked: 20 times
- Been thanked: 39 times
Unsealed bearings allow you to change damaged ones, instead of the entire unit, and some people argue that sealed bearings are not as hard-wearing as seperate bearings...
1. Take the rear wheels off...
2. Ask someone else.
N.
N.
- Been thanked: 322 times
repost
Merlin, the sealed vs unsealed bearings are the same except the sealed ones are packed with grease and, well, sealed. You can't replace the balls piecemeal and you wouldn't want to.
I wouldn't recommend sealed bearings on a Beetle or split bus rear axle as the bearings are designed to be lubricated by the transmission oil.
To remove the rear wheel bearings I made a pair of hooked extensions for my two-arm puller out of two Ford Escort cylinder head studs.
- Been thanked: 98 times
Sealed bearings are the way to go if you have a lowered rear end as the unsealed bearings will not get the required lubrication. Removing the bearing is a pain, I have in the past welded 2 plates to the bearing face onto which the bearing puller has something to bite into.
