FOR SALE: Porsche VDO gauges
Get your parts here
Porsche 924 tach & engine management combo gauge. The plastic pointed lens of the tach is cracked, but these are usually replaced by flat glass for use in a VW.
R 350 each, or R 650 for both
Complete 924 cluster with near mint gauges - R 550 each, or R 1500 for all
stew 89
Has thanked: 12 times
Re: FOR SALE: Porsche VDO gauges
Post by stew 89 »
Ill take the tack.... please
I'll take the speedo please Pine
Suggestion, name change to gaugefanatic. :mrgreen:
karmakoma wrote:Suggestion, name change to gaugefanatic. :mrgreen:
:lol:
I have a problem. What more can I say. Anyway, I need the speedo to complete my set. Have been waiting to buy one for ages.
*BUMP* - tach & 2 x engine management gauges still available
Pine wrote:*BUMP* - tach & 2 x engine management gauges still available
What size are these gauges pine ??
May want to take the Eng. Management gauge and have the face converted to oil temp & pressure, if it will fit into type 3 dash.
Type 3 has 85 mm hole 90 face.........
Won't fit, been there done that. I've fitted a 944 speedometer in the main speedo hole with the rev counter mounted under the dash. Works well and the speedo is very accurate :)
