TDi Conversion??? - Rotary Diesel maybe???
riaanj
Been thanked: 41 times
Post by riaanj »
Maybe one of you guys out there can give me some advice.
I'm thinking of getting a bus, would like to look into doing a TDi conversion on it using a 1.9TDi or 2.0TDi Golf/Jetta motor. I've seen many conversions like that done in the U.K, nobody tells what engine management system they use. My question is - do you get an aftermarket engine management system for TDi motors? Everything else is not too difficult to get or manufacture here.
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
riaanj
Re: TDi Conversion???
Post by riaanj »
Somebody???...................................................................................................................
Anybody???
Honda CBR600RR
Honda CBR600F4
Speak to Stuart Syncromad about this. He runs a mechanical pump on the 1.9 motor...
riaanj
Post by riaanj »
Thanx Blitz, I'll speak to him about that..
Honda CBR600RR
Honda CBR600F4
syncromad
What model do you have?: '68 Fasty,'75 Fleety
Post by syncromad »
Hi Riaan
why a TDi? first, do a 2.0i Golf, rev better and drive nicer, my TDi is in a syncro, cruises nicely at 90-100, 2.0 i will cruise in the same set up, a syncro at 130/140 easily and top out at 170. take it you want to fit it to a bay. Golf 2.0 will be more fuel efficient and drive much nicer,
stuart
083 629 9951
riaanj
Post by riaanj »
Well I was thinking of the TDi because it's not something you see everyday in S.A. I'm thinking it's not going to be as straight forward or easy as a w/c petrol conversion, the idea is to do it in a bay yes, had some experience with transplanting motors in them, I helped with a 2.0l skyline motor in my dad's double cab bay and a 1.8l golf motor in my uncle's bay..
? 2.0 Golf more fuel efficient than a TDi ?
I haven't been able to find any aftermarket management systems for diesel motors except the programmable one that Bosch does, but that's in the region of R80000-00 and that's just plain crazy!
Honda CBR600RR
Honda CBR600F4
riaanj
Post by riaanj »
This might be my answer?!? maybe???
A diesel rotary motor - http://www.wankel-ag.de/seite1_e.html
Honda CBR600RR
Honda CBR600F4
Bratjie
What model do you have?: 74
Re: TDi Conversion??? - Rotary Diesel maybe???
Post by Bratjie »
riaanj wrote:This might be my answer?!? maybe???
Power output seems a little low?
Esté robusto, ser fuerte!!!!
73 Beetle project
riaanj
Post by riaanj »
It does seem a little low but its DAMN interesting!
Honda CBR600RR
Honda CBR600F4
Has thanked: 45 times
Been thanked: 208 times
Interesting that the weight is only 25kg for the smaller version and 35kg for the larger one.
It still uses sparkplugs, so it's not really a compression-ignition engine. Uses two-stroke oil. (Maybe it helps lubricating the rotor seals).
Fuel consumption of 300g/kwh is still thirsty and in the petrol engine class. (Newer generation TDI's and even 40 year old Deutz engines uses only about 200g/kwh) diesel.
Very interesting concept.
I`m in the proses of building a straight axle conversion for split bus and then fitting a Rotary Turbo in to the splitty that will olso be a first or not :lol:
riaanj
Post by riaanj »
Bugger wrote:I`m in the proses of building a straight axle conversion for split bus and then fitting a Rotary Turbo in to the splitty that will olso be a first or not :lol:
First one I know of... :)
(Just off the topic quick - Bugger, what management system do you use for the rotary motors?)
Honda CBR600RR
Honda CBR600F4
YvaneS
What model do you have?: :)
Has thanked: 11 times
Post by YvaneS »
Microtech?
YvaneS wrote:Microtech?
Yip Microtech
But on the bus I am going to try the Spitronics want to see if the Guys can put their chips on the table
So I hope it works out
riaanj
Post by riaanj »
Yip Microtech
Let us know how that works, I've heard from a lot of people that Microtech is the best for running rotary's, I see Gotech say they can run rotary's too now, never seen or heard of somebody that used a Gotech on a rotary, I'm a bit sceptical about the Gotech..
Honda CBR600RR
Honda CBR600F4
