Hi guys
Anyone have information on fitting a fibreglass Jeep body to a beetle pan. I have the info on shortening it. Just a bit stuck with the actual fitment of the body. Apparently spacers are used between the pan and the body, wouldn't mind seeing some pics of the process, don't want to take any chances and bugger it up.
Donovan
Veep?
dlagerwall
- What model do you have?: 1974 beetle
- stew 89
- What model do you have?: kombi
- Has thanked: 12 times
Re: Veep?
Hey Don
About time you showed your head... Im sure you'll find all you need on this site... Ill also look for some info for you.
From what I know (and its not much) You don't need the spacers, But they will go a long way into making your Veep look more Jeep Ha ha.
You could make your own out of box tubing, should also make you pan a lot stiffer...
Good luck bud.
Good luck bud.
SuperbeetleNO244
- What model do you have?: 1967 and 1976
Re: Veep?
Hi my VEEP has 50mm square tubing used to raise the body up from the chasis. Then there is a ladder chasis which the veep body is bolted onto.
