Here's something you don't see every day: an original Puma twin carb' set...
What's here:
Matched set of original Solex 40mm carbs
Original linkage
Original filters*
Original Puma intake manifolds
Notes:
* One of the filter tops has been modified to take a breather pipe.
The linkage rod seems to have been extended somewhat messily with a barrel nut.
PMB-ish area.
4k
"Understeer is when you hit the wall with the front of the car, and oversteer, the rear. Hp is how fast you hit the wall, and Torque is how far you take the wall with you."
Pine wrote:Nice! On original Puma carb setups the pivot point was mounted to a bracket brazed to the fan housing
Thanks Pine.
In that case, I don't think anything is missing from it.
I'm not keen to sell it overseas, oemfoefoe. Sorry to disappoint.
I have another offer under consideration. Thanks for your offer though.
