I thought the bus was idling a little high so I went to do the norm of adjusting the Fast Idle Adjusting screw (as I'd do on the 1200 in the bug). It then began to stutter during idle if not set high revs it initially was set to. I did a bit of research and came across this (it's quite a read so hereunder I've summated the article): http://www.vw-resource.com/34pict3.html#carb
"34 PICT-3 Carb setting:
1) Warm engine and turn off
2) Back off fast idle screw
3) Check the choke is open and set the fast idle screw clearance to 0.003 at the lowest point on the fast idle cam
4) Then turn the screw in precisely ½ a turn
5) Turn out the bypass screw (the larger screw) on the left of the carb 2-3 turns
6) Screw the volume control screw (the smaller one) in until it bottoms out – not too tight but closed
7) Now unscrew it exactly 2 ½ turns
8 ) Start engine again to make sure it’s fully warm (choke fully open)
9) Now set the idle with the bypass screw (the larger screw) by turning in or out (probably out) to set idling to fast idle (850 rpm)
10) Now go back to the volume control screw and adjust slowly to get the fastest, smoothest running idle speed (probably screwing out) Not more than a half a turn either in or out
11) Then turn the volume control screw IN very slowly until the revs drop buy 20-30 rpm (slightly leaner) – could be an adjustment as little as 1/8 turn in
12) Go back to the bypass screw (larger one) and reset idle speed to 850 rpm
…. done ☺"
I tried this after work yesterday and had no luck at all
I've managed to get it to idle again by opening both the volume control screw and bypass screw almost all the way. I then closed each one one bit at a time (as each would drop the revs slightly) in a sort of "one-for-one tuning" method.
It seems to idle okay now and wasn't cutting out when I took it for a run last night but I've yet to start it from cold and see if it fires, which will be the true test.
What I don't like is that both the volume control screw and bypass screw are way off the settings given in the article above. Can anyone perhaps shed a little light?
Ta muchly!
