THE PARTS ALONE ARE WORTH MORE.
1st The owner should have had an oil filter on his carbs and everthing would be ok..Muderick wrote:@ Rui and Vader
Dont know if you guys still think if this is a bargain.... Owner decided to sell after someone told him that this engine and driving the sand dunes dont mix. He said that the sand could be seen in the oil when he took the 'siffie' off underneath.... Also it only needs rings to run again...![]()
This "2.3l" motor consists of:
Standard beetle engine casing
82 mm kombi / Oettinger crank
Standard beetle camshaft
94mm piston kit from Master Parts
Standard Beetle heads
Alternator
Standard Beetle distributor
Solex 34PICT carburettor
