Page 1 of 4
turbo time!!! panel beating
Posted: Thu Jan 26, 2012 6:53 pm
by vuyo
Hi guyz I guess its time for me to join the turbo revolution
As most of you know I have a beetle with a 1.8 8v golf engine
So I decided to turbo charge it so I got hold of a 1.9 Polo TDI turbo I don’t know what size it is but I estimate that it’s a T2?
bolts on to the head no neet for modz
Its gong to be a blow through system , the charge is going to blow into a 36DRLA carburetor that’s turbo prepped
The biggest challenge I had to face was creating an inlet manifold to accommodate the DRLA , so I got 12mil thick aluminum plate and fabricated a flange and some 38 mil tubing to feed the carb into the inlet and got it all welded up.
Space is an issue the throttle wheel needed some space so I cut out a little chunk out the bug
Next step fabricate a turbo hat.
Re: turbo time!!!
Posted: Thu Jan 26, 2012 8:47 pm
by DR WATSON
I will following your thread with great interest
Re: turbo time!!!
Posted: Thu Jan 26, 2012 8:52 pm
by vuyo
couldint sleep so i went digging in the garage i found a drill bit box thats perfect for my turbo hat i dont think id cut it up its a vintage item so i think il be going to fleet steel tomorrow, the box is a good reference point it has all the dimensions i need for the hat
Re: turbo time!!!
Posted: Fri Jan 27, 2012 10:54 pm
by vuyo
fabrication of hat started will make the bottom out of left over ally and the top out of mild steel hope to go to fleet steel tomoro to get some square tubing then the weding starts
Re: turbo time!!!
Posted: Sat Jan 28, 2012 6:06 am
by JonnoDub
Good luck with the turbo project and keep us posted!
Re: turbo time!!!
Posted: Sat Jan 28, 2012 8:53 pm
by vuyo
JonnoDub wrote:Good luck with the turbo project and keep us posted!
thanks dro ferst time in doing this hope i dont fukup
im open for advice
Re: turbo time!!!
Posted: Sun Jan 29, 2012 12:28 am
by karmakoma
Interesting project Vuyo, hope you fitting bigger brakes as well
Your topic reminded me of a silly movie I saw years ago...
It's Turbo Time !
http://www.imdb.com/media/rm3969816832/tt0116705
Re: turbo time!!!
Posted: Sun Jan 29, 2012 5:59 pm
by vuyo
hi karma iv got golf disck brakes so i think im fine
Re: turbo time!!!
Posted: Mon Jan 30, 2012 11:35 am
by JonnoDub
Remember that you need to lower the compression otherwise your head gaskets wont last ! Also a dumpvalve , wastegate and intercooler would be nice!
Re: turbo time!!!
Posted: Mon Jan 30, 2012 12:15 pm
by vuyo
JonnoDub wrote:Remember that you need to lower the compression otherwise your head gaskets wont last ! Also a dumpvalve , wastegate and intercooler would be nice!
i've taken all that into consideration
.compression? iv got a 3mm copper head gasket
.wastegate? come with the turbo
.dumpvalve? will get as soon as i start bending boost pipes
.intercooler? still looking for a polo tdi one.
thanks for showing interest JonnoDub it's much appreciated
Re: turbo time!!!
Posted: Tue Jan 31, 2012 7:19 pm
by vuyo
turbo hat under construction
Re: turbo time!!!
Posted: Wed Feb 01, 2012 6:42 pm
by vuyo
Re: turbo time!!!
Posted: Thu Feb 02, 2012 5:35 am
by JonnoDub
looking good there Vuyo ! Are you going to rejet that carb to allow for more flow or are you just going to keep your boost low?
Re: turbo time!!!
Posted: Thu Feb 02, 2012 7:51 am
by vuyo
JonnoDub wrote:looking good there Vuyo ! Are you going to rejet that carb to allow for more flow or are you just going to keep your boost low?
howzit Jonno i dont know about the jeeting yet because i havint run the car with the new carb yet il have to run it under load and see if it needs rejetting if im lucky the jetting in the carb is perfact but i doubt it. im planning on bossting at 0.5 bar.
Re: turbo time!!!
Posted: Thu Feb 02, 2012 1:39 pm
by vuyo
mock up fabrication of the boost pipes. I will go to the pipe benders on saterday
