Type 4 2366cc engine
Get your parts here
4agedub
Been thanked: 13 times
Post by 4agedub »
This engine was in my dad's cabrio for a short while untill we decided to go a different route with the car.
It was built in June 2010 and has run a total of + - 1 hour with max 5000rpm and 0.3 bar boost.
The specs are:
CU engine case
Type 4 71mm crankshaft with balanced rods
New mains, big ends and cam bushes when it was built.
Magirus Deutz sleeves that has been shortened and opened up
Chev v8 60 oversize pistons (103mm)
Vanderlinde cut cam, mild enough for turbo but still enough duration for n/a as well. I think it was a 272'
CJ cylinder heads that have been opened up for the Magirus Deutz sleeves. Stock porting and stock valves.
8,5:1 compression (If I remember correctly)
Stock t4 oil cooler
2lt flywheel
Here's what the engine sounded like with the turbo. It has plenty torque and runs really nice!!!
Not included that you will see on the video:
Fan housing, crank pulley, electronic distributor, intake manifolds upwards and oil cooler adaptor. These will be bolted to the engine we intend using with the turbo. So basically just the engine is for sale.
I have not decided on a price yet... but am open to offers. Please pm if you are interested
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
4agedub
Re: Type 4 2366cc engine
Post by 4agedub »
4agedub
Post by 4agedub »
Looking to get around R8k for this engine.
Might be interested what does come with the motor or sub ?
4agedub
Post by 4agedub »
Pierre, hierdie is die enjin wat op die vloerpan hier by Gotech is.
Basies is dit slegs die sub wat ek wil verkoop. Sal die naweek bietjie krap by die huis vir 'n std t4 oil cooler en distributor wat sal saam kom met die enjin. Ons gaan eerder die groot type 4 gebruik vir hierdie projek. Ek het 'n 2700cc type 4 wat perfek gaan werk met 'n lekker turbo.
Wentzel
Post by Wentzel »
Hi,
If Pierre doesn't take it and you're not in a hurry I will be interested. What will I need to convert it to upright for a Beetle?
Wentzel
Oxyboxer Project
4agedub
Post by 4agedub »
To convert you will need:
-Upright fan housing converion (IMPI, Volkspares or make one yourself. google Joe Cali conversion)
-Carburetor, dual carbs or custom intake manifolds for a throttle body
-External oil cooler
-Exhaust system
-1800 flywheel and clutch assembly
4agedub
Post by 4agedub »
Volkspares fan housing
DTM conversion
Joe Cali Conversion
HI
As mentioned today just waiting a reply from a friend then I can give you the Y/N Answer
So no Fly wheel with ?
4agedub
Post by 4agedub »
Ek gaan die 1800 flywheel hou.... het hom nodig vir die ander engine. Ek sal 'n 2lt flywheel saam gee.
4agedub
Post by 4agedub »
Bump
AirPower
Been thanked: 4 times
Post by AirPower »
Hi
Are the pistons forged or cast?
Mario
4agedub
Post by 4agedub »
I'm not sure... I think they were cast pistons. Will check tonight as I still have 4 left from that specific set.
AirPower
Post by AirPower »
SJOE!
You boosted that motor? 8,5:1 compression and cast pistons?
I hope you were behind a lexan screen :mrgreen:
The best offer I can do is R3500, on condition that I can have a look at the piston tops?
4agedub
Post by 4agedub »
These are the pistons:
The make is Badger. It is a hypereutectic piston. So basically a new generation cast piston.
Yes, it was boosted, but only 0.3bar. That is basically just an altitude compensator. Going to the coast from where we are it's as good as running 0.2 bar boost. The air pressure in JHB is around 83kpa... at the coast 101kpa. If the pistons cannot handle that kind of boost... then they are crap.
Mmmn... no thank you
The engine is in perfect condition... I am in no doubt of that. On request I can start the engine for the prospective buyer to check. Once the buyer has paid then he can do whatever he wants.. like open the engine.
