Rebuilding / Refurbishment by Bugger now VdubTECH
As projects come along I will add some Pics here for you guys to look at
Beach Buggy Rebuilt / Refurbishment
As progress goes on I will ad currently Chassis is in for Snd blasting and all the Roll and Bull bars will get Powder coated
Buggy will go Monster Green and Sparkle Silver
Mag wheels are also getting a lick of the Monster green Paint from the Ford Focus RS these paint are Quite Expensive per liter and is a 3 Stage paint
Which Consist of a Base Cote then the Pearl Cote and finally the Clear cote over the previous 2 cotes
This Buggy will Look stunning when Finish and it will Get a twin Carbs Air cooled motor with lots of Bling
Trying to load the pics again
Re: Rebuilding/Refurbishment now by Bugger
Some Progress and update
The Monster Green / Ultimate Green comes from the Ford Focus special Edition RS and is a 3 Pack paint
You first apply the Green
Then the Pearl
And then the clear coate over both and it has a slight Gold glitter in the pearl as well
What we did was Applied the Green then Masked all the areas I wanted to have the silver and then took off all the Masking paper
There after we Applied the Pearl as I wanted the Sparkle Silver to have the Pearl effect as well and I think it was a Good plan
as it brought the sliver out very good
Then the Pearl
Some more update Pics
- Drusky
- Has thanked: 77 times
- Been thanked: 15 times
I would love to see a chassis built for that 356a kit car. Something with an aircooled upright IMPI mill and a good suspension setup... who builds chassis?
What Chassis are you looking for ?
A std Beetls Chassis modified or a Tube chassis ?
- Drusky
Not really looking but learning and observing. Tubular chassis. There must be guys who do this.
- arnocill
- What model do you have?: beamish buggy
- Has thanked: 6 times
- Been thanked: 4 times
Personally i don't like green, but
on the build quality and detail. It really looks great!
on the build quality and detail. It really looks great!- Hloni
- Has thanked: 14 times
- Been thanked: 11 times
Bugger, is that square tubing or angle line on the chassis? What guage/thickness is it? Would love to see more pics of it as I am in the process of building a buggy.Bugger wrote:Some more update Pics
Who done your Gear Box...........Bugger wrote:.....
Transmission also done in the Green and refurbished
The guys that build the Track tubular chassis wil be able to do something spacialDrusky wrote:Not really looking but learning and observing. Tubular chassis. There must be guys who do this.
Retrovan a Magic wand did the Gearbox
Hloni that is Angle Iron used 5mm thick
Thanks arnocill just takes alot of man hours
- MarshallGTi
- Camshaft
- Has thanked: 7 times
i does lykitallot!
Ryan Marshall
- Hloni
Bugger, you able to show more pics of that chasis/frame or is that patent design
Hloni wrote:Bugger, you able to show more pics of that chasis/frame or is that patent design
Thats the only pics I got
