Some advice needed: Donor beetle for Buggy Project
julietwhiskey
What model do you have?: '71 Beetle
Has thanked: 2 times
Post by julietwhiskey »
Hi, apologies if this post is in the wrong place. Moderator please move.
I have plans building a beach buggy. Obviously the first logical step is to have a proper donor beetle (apart from the funds, time, skills, experience, etc. etc. that usually strangles such ambition). I have been advised to ensure that the base of the buggy is sound, and importantly, compliant with current license regulations i.e. on the road and currently licensed (I have gained some good insight on the forum of the highs and lows of this process).
I have a fundamental problem chopping a fairly decent car and have obviously been looking for that "abandoned beetle standing in a barn" that will do much better as a buggy. It seems as if these beetles have been "left at the altar" (ex-student cars :) ) and are available... but enter the latter part of the advice - paperwork.
One is then left with the dilemma to chop (and pay premium and possibly kill a potential classic) or take what is available and as close to "left at the altar", but with paperwork. In this category you also face the Code 3 car issue, which I don't have an issue with as such, as long as the mechanics and structure checks out, as the body will not be required. However, the body may offer some clues as to why the donor ended up as a Code 3 and I would appreciate any advice in this regard based on member’s experience:
My direct concern is the structural integrity of the Tunnel, Frame head (?) and Rear suspension i.e. "chassis" . The car I'm looking at has clear signs of body repair work on the font side, indicating a major shunt as some point and bonnet definitely a replacement. The rest of the dents seem minor wrt impact, but the roof also indicates quite a bit of history (hail storm?, rolled over? driven under a higher vechile? roadsign hitting the roof?)
So my questions are:
> Are there any "tests" / "checkpoints" to look for and ensure that the beetle chassis is not twisted (out of level) or bent (out of square) whilst the body is on?
> I intend going the SWB route - so can these types of deficiencies be corrected as part of the shortening process? (If you know of professionals that do this kind of work in JHB / PTA area I would appreciate any contacts via PM.)
> Rust on the floor-pans are easy to spot, but how durable is the tunnel section as a rule?
> Are there any "non-acceptable Beetle behaviours" that may indicate problems with the drive line whilst testing on the road?
> What would a body be worth in a worst case scrap metal scenario? (I don't intend keeping the body for too long and would like to spend wisely.)
Thanks JW
Thanks and regards / Dankie en groete
JW
Re: Some advice needed: Donor beetle for Buggy Project
julietwhiskey wrote:Hi, apologies if this post is in the wrong place. Moderator please move.
Alot of Beetles ended up as Scrapped (Papaer wise and not Acident damage) and then "Rebuild" and re introduced in the old Systems that is why there are lots of code 3`s and alot was just left and not licence paid in the old old system then it became sort off Dormant and gone to code 3
Checking by Eye is a bit difficult but just look from a distance to the front how the wheels sit and Tyre wear front and back
A beetle suspension can take Quite a bit of hammering most chacks is in the bonnet to see if the car was in a Accident before and the back valance
I am not sure if DAW does pan shortening but Replicars sure think they do still
aslong as the tunnel was not cut for Clutch cable repairs then the tunnels are quite strong with the side panels on
The normal obvious thing pulling hard on the steering could indicate damaged syuspension or just plain Wheel Alighnment
test the brakes and see how the car pull when braking
Depending what it Weigh and the price of steel depending on how long is not long that you will be keeping the shell
Sometimes it is good to buy a Cheap Buggy as a donor and Rebuild it your sef as most of the hard work is done
Thanks JW
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
Might be better if you update your user profile to show where in jhb you are based
julietwhiskey
buggyfan wrote:Might be better if you update your user profile to show where in jhb you are based
Thanks, done. Randburg.
JW
MELLO YELLOW
Post by MELLO YELLOW »
Why go the route of cutting a beetle body
If you are interested I have an extra beach buggy body that I am not goint to use
let me know
julietwhiskey
MELLO YELLOW wrote:Why go the route of cutting a beetle body
let me know
Thanks, I did (try and) send a PM. Or PM me with more details.
JW
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
Hi
Some advice
You will need the following from a donor beetle
Complete rolling pan (if your pan is from a 1973 or later beetle it wont have numbers stamped making registration less of a problem as the car will be registered as a built up vehicle that will happen if the beetle has papers anyway
the state is not very particular about engine numbers as long as its not stolen.
there are a few other parts to find
Fuel tank
speedo
complete steering collumn
maybe tail lights
These are all easy to find parts and my advice is not to set your heart on a complete beetle there are lots of roller pand for sale.
Look at Hw2.s build thread to see how we manage the pan I have found this the best way to do and have personally built 4 similar chassis for buggies. As you will see having rust free floors is actually a disadvantage.
julietwhiskey
Tx Impi, sound advice. The HW2 project is really a nice story and lots of info.
Watch out for PM.
JW
