Cooler running engine
VW1600S
What model do you have?: 69-1500/72-1600/
Post by VW1600S »
Check this addition claimed to help cooling the engine:
http://www.awesomepowdercoat.com/Venturi_Ring.html
Kinda makes sense, if it's used on carbs ...
Re: Cooler running engine
In the OLD days we called it a RAM TUBE, and all Hot Rods guys fitted the same thing to there carb's,
Before they realised that you do need a Air Cleaner to save the engine....... :lol: :lol:
It works on the theory that the intake is bigger, then the larger amount of air is compresses more, before entering the chamber.
So the volume of air is increased.
Hope it helps.
